Author Topic: ATI Radeon 7000 Card with soft15khz  (Read 3052 times)
ryanw87
  • Last login:December 09, 2011, 05:41:32 pm
« on: November 10, 2011, 08:46:45 pm »
Hello ive been spending alot of time searching if this graphics card will work with soft15khz and couldnt fins an answer since most people are using agp or pci-express bus and my pcs that old i need PCI
the card is - ATI Radeon 7000 64MB DDR PCI Video Card
If this card is no good could anybod give me some cards that use the PCI slot and are compatible with soft15khz?
thanks for any help you can give.
Ryan
SailorSat
  • Last login:September 24, 2026, 05:58:15 am
    • For Amusement Only e.V.
Re: ATI Radeon 7000 Card with soft15khz
« Reply #1 on: November 11, 2011, 10:18:12 am »
Every PCI version should work if the AGP or PCI-E version works.
I do all that stuff even without a Joystick ;)
Soft-15kHz, cabMAME, For Amusement Only e.V.
ryanw87
« Reply #2 on: November 11, 2011, 01:36:08 pm »
ok thanks alot
MTPPC
« Reply #3 on: November 14, 2011, 03:14:07 am »
I just did this. Soft15k told me to use Catalyst 6.5 driver for the video card. My card was an AGP radeon 9200 LE.
http://pinballmd.com/
