Author Topic: Groovy Arcade Linux doesn't work with Radeon 9200 PCI  (Read 5946 times)
mazinger-z
  • Last login:January 03, 2016, 12:50:47 pm
« on: November 10, 2011, 05:34:40 pm »
Hello, I tried the ISO (both 32 bit and 64 bit versions) with a Radeon 9200 PCI (Vendor 1002, Device 5960, Subsystem 1051196, Rev. 01) and it didn't work. The system boots into a nice interlaced menu, but when I try to make the video setup or to start the front-end, I get an error.
Here is the log (I'm not a Linux user but managed to mount the floppy drive and get the log on a disk):
Code: [Select]
[   110.917]
X.Org X Server 1.9.2
Release Date: 2010-10-30
[   110.923] X Protocol Version 11, Revision 0
[   110.926] Build Operating System: Linux 2.6.38-rc1 i686 Gentoo
[   110.929] Current Operating System: Linux GroovyArcade 3.0.2+ #1 SMP Wed Aug 17 14:02:42 CDT 2011 i686
[   110.935] Kernel command line: real_root=/dev/loop0 looptype=squashfs loop=/livecd.squashfs initrd udev nodevfs cdroot doscsi video=VGA-1:640x480ec
[   110.943] Build Date: 31 January 2011  12:08:30PM
[   110.948]
[   110.953] Current version of pixman: 0.20.0
[   110.958] Before reporting problems, check http://wiki.x.org
to make sure that you have the latest version.
[   110.967] Markers: (--) probed, (**) from config file, (==) default setting,
(++) from command line, (!!) notice, (II) informational,
(WW) warning, (EE) error, (NI) not implemented, (??) unknown.
[   110.982] (==) Log file: "/var/log/Xorg.0.log", Time: Sun Nov  6 12:10:46 2011
[   110.988] (==) Using config file: "/etc/X11/xorg.conf"
[   110.994] (==) Using system config directory "/usr/share/X11/xorg.conf.d"
[   111.108] (==) No Layout section.  Using the first Screen section.
[   111.108] (**) |-->Screen "Screen0" (0)
[   111.108] (**) |   |-->Monitor "VGA-0"
[   111.109] (**) |   |-->Device "Card0"
[   111.109] (==) Automatically adding devices
[   111.109] (==) Automatically enabling devices
[   111.109] (==) FontPath set to:
/usr/share/fonts/misc/,
/usr/share/fonts/TTF/,
/usr/share/fonts/OTF/,
/usr/share/fonts/Type1/,
/usr/share/fonts/100dpi/,
/usr/share/fonts/75dpi/
[   111.109] (==) ModulePath set to "/usr/lib/xorg/modules"
[   111.109] (II) The server relies on udev to provide the list of input devices.
If no devices become available, reconfigure udev or disable AutoAddDevices.
[   111.109] (II) Loader magic: 0x81f2d60
[   111.109] (II) Module ABI versions:
[   111.109] X.Org ANSI C Emulation: 0.4
[   111.109] X.Org Video Driver: 8.0
[   111.109] X.Org XInput driver : 11.0
[   111.109] X.Org Server Extension : 4.0
[   111.110] (--) PCI:*(0:1:10:0) 1002:5960:196d:1051 rev 1, Mem @ 0xd0000000/134217728, 0xdf7f0000/65536, I/O @ 0x0000d000/256, BIOS @ 0x????????/131072
[   111.110] (--) PCI: (0:1:10:1) 1002:5940:196d:1050 rev 1, Mem @ 0xc8000000/134217728, 0xdf7e0000/65536
[   111.110] (II) LoadModule: "extmod"
[   111.111] (II) Loading /usr/lib/xorg/modules/extensions/libextmod.so
[   111.262] (II) Module extmod: vendor="X.Org Foundation"
[   111.262] compiled for 1.9.2, module version = 1.0.0
[   111.262] Module class: X.Org Server Extension
[   111.262] ABI class: X.Org Server Extension, version 4.0
[   111.262] (II) Loading extension MIT-SCREEN-SAVER
[   111.262] (II) Loading extension XFree86-VidModeExtension
[   111.262] (II) Loading extension XFree86-DGA
[   111.262] (II) Loading extension DPMS
[   111.262] (II) Loading extension XVideo
[   111.262] (II) Loading extension XVideo-MotionCompensation
[   111.262] (II) Loading extension X-Resource
[   111.262] (II) LoadModule: "dbe"
[   111.262] (II) Loading /usr/lib/xorg/modules/extensions/libdbe.so
[   111.262] (II) Module dbe: vendor="X.Org Foundation"
[   111.262] (II) Loading extension DOUBLE-BUFFER
[   111.262] (II) LoadModule: "glx"
[   111.262] (II) Loading /usr/lib/xorg/modules/extensions/libglx.so
[   111.453] (II) Module glx: vendor="X.Org Foundation"
[   111.453] compiled for 1.9.2, module version = 1.0.0
[   111.453] ABI class: X.Org Server Extension, version 4.0
[   111.454] (==) AIGLX enabled
[   111.454] (II) Loading extension GLX
[   111.454] (II) LoadModule: "record"
[   111.455] (II) Loading /usr/lib/xorg/modules/extensions/librecord.so
[   111.456] (II) Module record: vendor="X.Org Foundation"
[   111.456] compiled for 1.9.2, module version = 1.13.0
[   111.456] Module class: X.Org Server Extension
[   111.456] ABI class: X.Org Server Extension, version 4.0
[   111.456] (II) Loading extension RECORD
[   111.456] (II) LoadModule: "dri"
[   111.457] (II) Loading /usr/lib/xorg/modules/extensions/libdri.so
[   111.940] (II) Module dri: vendor="X.Org Foundation"
[   111.940] compiled for 1.9.2, module version = 1.0.0
[   111.940] ABI class: X.Org Server Extension, version 4.0
[   111.940] (II) Loading extension XFree86-DRI
[   111.940] (II) LoadModule: "dri2"
[   111.940] (II) Loading /usr/lib/xorg/modules/extensions/libdri2.so
[   111.940] (II) Module dri2: vendor="X.Org Foundation"
[   111.940] compiled for 1.9.2, module version = 1.2.0
[   111.940] (II) Loading extension DRI2
[   111.940] (II) LoadModule: "ati"
[   111.941] (II) Loading /usr/lib/xorg/modules/drivers/ati_drv.so
[   112.078] (II) Module ati: vendor="X.Org Foundation"
[   112.078] compiled for 1.9.2, module version = 6.13.99
[   112.078] Module class: X.Org Video Driver
[   112.078] ABI class: X.Org Video Driver, version 8.0
[   112.078] (EE) No drivers available.
[   112.084]
Fatal server error:
[   112.097] no screens found
[   112.104]
Please consult the The X.Org Foundation support
at http://wiki.x.org
 for help.
[   112.131] Please also check the log file at "/var/log/Xorg.0.log" for additional information.
[   112.145]
I also tried with an integrated GeForce 6150SE, but couldn't get past the menu, because only the top half of the menu was visible, due to black horizontal lines interleaved with the normal lines.
An ATi Rage PCI did work, but it always gave a signal >= 31KHz.
Please keep updating this wonderful project.
levIT8
  • Last login:October 24, 2012, 03:40:27 am
Re: Groovy Arcade Linux doesn't work with Radeon 9200 PCI
« Reply #1 on: September 05, 2012, 04:09:48 am »
Hi,
I have the same problem with 2012.06.09-i686, tested on two Intel integrated graphics cards and one ATI Radeon HD 2600 (AGP) card  - received the "no screens" error each time. I only managed to get it work (sort of) on my laptop with an nVididia GeForce GT 330M, but only if I select "SVGA" as monitor type.
Is it maybe required to make some configurations changes in order to get this to work at least on the Radeon card?
Anyway, thanks for the great effort. Once this works fully, connected to my huge old Grundig TV set to get the true 15 kHz modes, I will be sure to make a donation!
Calamity
  • Moderator
  • Last login:June 01, 2026, 01:40:54 pm
  • Quote me with care
« Reply #2 on: September 05, 2012, 05:01:07 am »
Hi,
The Intel cards won't work, that's a fact. However it should work with your HD 2600, just make sure to try both outputs, DVI and VGA, from the live-cd boot menu, to force the right output.
Steps to create a log:
levIT8
« Reply #3 on: September 05, 2012, 05:09:00 am »
Many thanks, I will try different outputs on the Radeon as suggested and post again with the results. Keeping my fingers crossed!  :)
ves
  • Last login:April 11, 2020, 02:57:49 am
« Reply #4 on: September 05, 2012, 10:21:24 am »
Hello, I confirm radeon works, must be configured again xorg video section, or delete the file and re-configured from gasetup.
 ATI Radeon 9200(RV280) chipset
- PCI: 1002/5961
- Number of transistors (millions): 36
- 0.15um technology
- 128MB 64-bit DDR
- Real clock: 165MHz
- Effective clock: 330MHz
- Bandwidth: 2640MB/S
- Connector: D-SUB + DVI + Video
levIT8
« Reply #5 on: September 05, 2012, 06:39:16 pm »
After fiddling around for awhile I have reached some progress with the Radeon (HD 2600) card.
I can get X to start up properly but then advmenu dies immediately due to an "illegal instruction". Then X comes back down again so at first this looked like it was an X problem.
Turns out I'm not the only one having this problem:
http://forum.arcadecontrols.com/index.php/topic,117334.msg1298620.html#msg1298620
If I manually replace advmenu with groovymame in the .xinitrc file, MAME will start up and seems to work - except that in the MAME main menu keyboard response is very sluggish.
(Just for fun I tried to select Wah!Cade as the front-end but nothing happened, am I doing something wrong?)
