Author Topic: arcadevga and a scart tv  (Read 1929 times)
nnndoh
  • Last login:February 27, 2012, 04:59:27 pm
« on: November 10, 2011, 08:47:53 am »
i need input
I've build my own vga to scart cable ( very happy it works ) but autoswitch to AV doesn't work
when i connect the tv and computer monitor to the arcadevga, i see a boot screen on my computer monitor
then when i extend my desktop to my tv, i see a clear sharp image at every resolution
but, when i restart my computer with only the tv connected at the 15 pins connection
i see a sharp clear image of my boot screen, the windows is loading animation.
but then i see this...
what would cause this?
at first, resolution was set at 640 x 288.. what  weird is, if i want to choose another frequency, i see only a blank field.
would it solve the problem if i install windows xp instead of windows 7  64 bit?
« Last Edit: November 10, 2011, 09:29:26 am by nnndoh »
nnndoh
Re: arcadevga and a scart tv
« Reply #1 on: November 10, 2011, 04:18:57 pm »
problem solved, downloaded 64 bit drivers from ultimarc
