Author Topic: Hooking up trackball to Apache spinner. Weird things happen :( Pls Help!  (Read 1417 times)
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
Well I can hook it up and it will work, but then the spinner wont.  :banghead: The documents say it supports the spinner plus a trackball and 5 buttons.
Anyone have this problem or know how to fix it?
BobA
  • What Me Worry?
Re: Hooking up trackball to Apache spinner. Weird things happen :( Pls Help!
« Reply #1 on: November 05, 2011, 10:25:32 am »
Might be an assignment problem.   Since the spinner uses the x axis make sure the trackball uses y and z.  Just a guess as I never hooked up a trackball to it. :)  Or if you cannot set the trackball to use y and z and it uses x and y then use the onboard setting jumper on the BH board to make the spinner use the z axis.
« Last Edit: November 05, 2011, 10:33:43 am by BobA »
equlizer
« Reply #2 on: November 05, 2011, 04:43:20 pm »
K figured it out but still weird to me.  The trackball can not and will not use Z axis so i put the spinner on the Z axis and the trackball on X and Y.  The only program that recognizes Z is MAME.
