Author Topic: What is the best way to switch a DC to an Arcade Monitor ??  (Read 1003 times)
MrPoPo
  • Last login:March 10, 2004, 05:53:46 pm
« on: September 15, 2003, 04:46:36 pm »
Hi group !!
What is the best way ??
I have a 15KHz Arcade Monitor.
Luxury
  • Last login:November 18, 2006, 01:21:59 pm
  • Unfortunately It's True. :(
    • arcadeZERO
Re:What is the best way to switch a DC to an Arcade Monitor ??
« Reply #1 on: September 15, 2003, 05:22:31 pm »
Easy.  Click on [Game Consoles] on the left, and then on [Dreamcast to Arcade Monitor]
Ph'nglui mglw'nafh Cthulhu R'lyeh wgah'nagl fhtagn.
MrPoPo
« Reply #2 on: September 16, 2003, 05:13:22 pm »
Ok yes.
But my question is what is the best system to do it.
Hack an VGA Box or do the little circuit ??
And other question is if I can connect the PC and the DC to the same Jamma.When one works the other is power down and inverse.I don't want to change the jamma connector everytime.I only want a switch to select DC or PC.
Can you undersatnd me ? I'm spanish and my english is too bad,sorry.
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
« Reply #3 on: September 18, 2003, 01:23:46 am »
Are you using a PC to drive the arcade monitor already?
If so, add a TV card to the PC, and you can plug anything you want into it.  Then you can play anything on your arcade monitor.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
