Author Topic: regular jamma rgb to vga or lcd composite, is it posible?  (Read 2883 times)
abispac
  • Last login:June 24, 2026, 02:10:50 am
« on: October 31, 2011, 12:52:09 pm »
Hello , and thanks for reading, heres my problem, i got an xbox 1 that im trying to turn into a dedicated cab, i have the xbox to jamma adapter and it works just fine or arcade monitors, howeve, i would like to use this on a regular ldc screen , so i wonder if its posible to turn that rgb jamma output into a vga or the rgb composite that my lcd tv has. Im not really familiar with the rgb  that my tv has but i suposed that would be a bit easyer to venvert, thanks for any help.
Re: regular jamma rgb to vga or lcd composite, is it posible?
« Reply #1 on: October 31, 2011, 05:21:39 pm »
why not use the regular video out of the xbox into the LCD? Composite video is pretty terrible.
abispac
« Reply #2 on: October 31, 2011, 06:09:36 pm »
because im runing the xbox thru an xtimer jamma to pc, wich has the yellow rca video out, wich i think im going to use, but i was hoping to hook this out in a vga monitor, but ill make things a bit simple. thanks.
« Reply #3 on: November 01, 2011, 08:53:50 am »
you can convert the arcade signal to VGA, but it would probably be easier to hack xbox controllers and wire them up for controls and just forget about the jamma conversion then you can use component out or get an xbox1 VGA adapter.
look up "supergun" video converters and you should find what you need. I cant recall exactly what they are called.
BobA
  • What Me Worry?
« Reply #4 on: November 01, 2011, 10:44:45 am »
RGB to TV convertor. jrok
