Author Topic: joystick and push button confusion  (Read 17700 times)
  • Last login:Today at 06:03:45 am
Re: joystick and push button confusion
« Reply #40 on: June 24, 2012, 04:59:32 pm »
Can anyone tell me the size hole I should drill for the zippy joystick? Also is it the same size for the GGG Arcade Prime pushbuttons?
A Zippyy mounted under 3/4" MDF can use a hole between 3/4" and 1 1/8" wide.
The closer you get to the upper and lower extremes, the better you have to center the stick.
3/4" is the absolute minimum size so the shaft doesn't hit the sides.
1 1/8" is pretty close to the maximum size so the dust washer covers the center hole. when the joystick is pushed to any angle.
The dust washer for a Zippyy is designed to rest on top of the CP.
Arcade Prime pushbuttons = standard 1 1/8" hole.
