Author Topic: Dimension of Ultrastik 360 shaft  (Read 1822 times)
cammada
  • Last login:February 19, 2026, 08:29:29 pm
« on: October 24, 2011, 10:03:55 pm »
Does anyone know the exact dimension of Ultimarc UltraStik 360 shaft?
AndyWarne
  • Trade Count: (+18)
    • Ultimarc
Re: Dimension of Ultrastik 360 shaft
« Reply #1 on: October 25, 2011, 06:48:15 pm »
The length of the standard handle is 36mm from the faceplate to the underside of the ball.
cammada
« Reply #2 on: October 26, 2011, 09:50:57 pm »
don't you have a plan - similar to this picture from "http://www.thludwig.de/arcade/pics/LED_sticks/size_jlf-tp-8yt.jpg"?
This is because I am planning to get Ultimarc J-Stik and I know that no one is making hollow JLW-TM-8 shaft anymore. I need to know if LS-32 will be compatible with j-Stik?
AlienInferno
  • Last login:June 15, 2026, 07:20:11 pm
« Reply #3 on: October 26, 2011, 11:40:35 pm »
Talk to Luigi on these forums.  He should be able to get you some JLW-TM-8 hollow shafts made.
