Author Topic: pga golf vr-gobal  (Read 307152 times)
ed12
Re: pga golf vr-gobal
« Reply #160 on: July 28, 2012, 03:27:08 pm »
hi
these are your edit point's
pay attenion to 3dfx,as hercules need's and point's to it
now to edit get all of dll's for the new video card
rem out the old driver's :DO NOT REMOVE THEM:.
place in your u dated video driver's
the other file's are to show u were we go with this proggie
ed
ed12
« Reply #161 on: July 28, 2012, 07:27:58 pm »
hi
i just tried something
and knowing your video card is deteced,by windows at least
u could re-load the driver's and point it to hercules/3dfx,it should load your dll's..
then it should just over=write your current window's video driver's
also if u are strong in window's system32 u could manualy pull the nessary driver's
or u can .zip the installer post it
i will get it and c what can be done,i have just done a test using the up-method
seemed to work
ed
CVN53
  • Last login:December 24, 2013, 10:33:27 am
« Reply #162 on: July 29, 2012, 10:02:37 am »
Hi Ed
 I am not sure what u what me to do with the old drivers,do I place them in another folder and where?I have no clue how to use the hercules setup program.I am not a coder so I will need some step by step instructions.I will zip up the exe for ati card in a bit so you can look at it.Hope I am not putting you out to much because I lack understanding of what you are trying to get me to do.
Thx appreciate all your help in getting this game working again.
CVN53
CVN53
« Reply #163 on: July 29, 2012, 10:38:54 am »
Hi Ed
Here is the ati setup.exe
sry attachment to big
Thx CVN53
« Last Edit: July 29, 2012, 10:51:40 am by CVN53 »
ed12
« Reply #164 on: July 29, 2012, 11:39:16 am »
hi
just .zip or .rar the file
it should up-load
and what i want u to do is basic vb
u do not need high level skill's
if u load the setup .exe and point it to hercles/the video file
it will not over write the .dll's in there
they should sit side by each
when i get back,i will do another test of this and post u the way
ed
CVN53
« Reply #165 on: July 29, 2012, 11:51:06 am »
Hi Ed
  Here is the link for 6-12_xp_dd_ccc_wdm_enu_38463.exe http://www.windowsdrivers.ru/drivers/download/ecs_radeon_9550_rex_128mb--secondary.html
about little  past half way down on the page
CVN53
dirt
  • Last login:October 30, 2024, 08:36:38 pm
« Reply #166 on: July 29, 2012, 11:55:47 am »
Hi ed, I figured out the reason for my monitor being so dark. Somebody bad turned down the gamma setting in the game menu. I now have as great picture.
I have another question. Everytime I turn the game on. It stops loading and say I have no card reader. I've swapped in another card reader. I've swapped cables. Is this normal because its not linked to vr anymore or is something wrong with my computer that I can check out?
Also mine is team challenge not championship edition.
Sent from my LG-P509 using Tapatalk 2
WANTED: NINTENDO CABINETS WORKING OR NOT
ed12
« Reply #167 on: July 29, 2012, 12:04:42 pm »
hi
dirt
can u post a pix of the back of your coumpter in that machine
i have a feeling that the usb cable is plugged into the wrong place
also if u do not want the player's card reader ?
it is a easy edit in hercules
and congrad's on finding that setting :)
ed
CVN53
« Reply #168 on: July 29, 2012, 12:10:16 pm »
Hi Ed
I am not sure how to use hercules to edit programs thats where I get confused
CVN53
« Last Edit: July 29, 2012, 02:21:55 pm by CVN53 »
dirt
« Reply #169 on: July 29, 2012, 12:23:19 pm »
Ill get the picture as soon as I get home, about an hour. I do want the card reader to work as I have a card.
ed12
« Reply #170 on: July 29, 2012, 05:13:32 pm »
hi
CVN53
u are not using hercules u are editing it
if u d/l the file's i up-loaded
them are some of the files u edit in :note-pad:
dirt
ok:) that's good to hear
most ppl want the player card
ed
CVN53
« Reply #171 on: July 29, 2012, 05:28:38 pm »
Ed
  Ok but I don't know how to get those files to note pad to edit,it seems like I am missing something.I have no cfg file that I can find.It looks like u use pe explorer to open but I don't have that program or know how to use it.
CVN53
dirt
« Reply #172 on: July 29, 2012, 05:29:52 pm »
Here is the picture of the back of the PC. It is the top right USB plug.
ed12
« Reply #173 on: July 29, 2012, 07:48:06 pm »
hi
dirt
thats what i thought
the cardplayer should plug into the aux usb port >the board with 4 usb ports on it
then the game dongle board can plug into the 4 way and or the main usb of the mobo thats the 1 i like best,but that is the reason for the 4 port card.
plus that card is usb 2 which is what the card reader's are
CVN53
hi yes pe explorer u can get it free
and if u have ever used a editor u will catch on fast
i am still trying to find your dll's..wish u had done a system 32 snap shot before and after the install,but i will get there from here bear with me
ed
dirt
« Reply #174 on: July 29, 2012, 10:32:20 pm »
I don't think I have a 4 port card in mine. I only see the 2 USB ports at the top of the tower.
ed12
« Reply #175 on: July 29, 2012, 11:22:57 pm »
hi
dirt
yes i c u do not
your problem will be that the card reader is usb2 and the mombo's usb port's
are usb1,c if u can find a 4 port usb card, it will be a pcmia
plug it in and then plug the reader into it
let me know
ed
CVN53
« Reply #176 on: July 29, 2012, 11:40:33 pm »
Hi Ed
No I have never used an editor,so when it comes to viruses, mb problems I can do that kind of stuff but I am pretty much in the dark with want you are doing here . So if I can get a step by step by step for this video card it would be nice,if it is to much of hassle let me know and I will quit posting,I know your helping people but this may be way over my ability.
Thanks for all your help.
CVN53
dirt
ed12
« Reply #178 on: July 30, 2012, 03:22:32 pm »
hi
dirt
 it will work perfect
CVN53
bear with me then,i will dig out the nessary .dll's and walk u through it
ed
CVN53
« Reply #179 on: July 30, 2012, 08:09:18 pm »
Ed
Sounds good I will wait for u I really appreciate all your time.
Thanks in advance
CVN53
ed12
« Reply #180 on: July 30, 2012, 08:54:46 pm »
hi
CVN53
i have spoken to a co coder
and they have said they will send me the .dll's
it's in the work's
ed
dirt
« Reply #181 on: August 03, 2012, 08:05:30 pm »
hi ed. i put the new usb card in and its still not seeing the card reader. i even plugged in another card reader with another cable and still nothing. what else should i try?
ed12
« Reply #182 on: August 03, 2012, 10:07:13 pm »
hi
dirt
give me a min i am gonna chk my .dir
and up-load the .cfg/dat
ed
ed12
« Reply #183 on: August 03, 2012, 10:32:45 pm »
hi
dirt
this is part 1 of 2
but this line apply's
drive leeter:\teen\Tournament\GvrSCShare
that will pertain to the second file
read the readme in the .zip
the share file's i will up-load in a byte
should fix your usb problem
which i find weird as usb2 is self deteting ??
but what ever
ed
dirt
« Reply #184 on: August 04, 2012, 12:24:20 pm »
hi ed,
  i forgot to mention that my game is team challenge not championship edition. i dont know if that makes a difference in the file you just posted. i'll wait to hear from you before i install it.
ed12
« Reply #185 on: August 04, 2012, 02:46:22 pm »
hi
dirt
it is team challange
i forgot last night to up-load the other 2 scr's
will get them up today
been busy building a new team......
complete sata driven
man is herc a jerk :):)
ed
ed12
« Reply #186 on: August 04, 2012, 03:22:55 pm »
hi
dirt
please read this
where u have team challange >>:\team\Program Files\Intel\InfInst
this is a editer for u
see if it is in it's proper location,this control's the usb uart
ed
dirt
« Reply #187 on: August 04, 2012, 03:30:36 pm »
Ill check it out when I get home in a couple hours. Ill post what I find. One question first, do I stop the golf program with ctrl alt del or escape or ???
« Last Edit: August 04, 2012, 07:43:48 pm by dirt »
ed12
« Reply #188 on: August 04, 2012, 05:19:20 pm »
hi
let me grab my test  unit
and i will walk u through it
going for yum yum rib's
then  i will snag it from the warehouse and bring it to the shop
we can walk through it ,same with the video issuie the other nick is having
i guess real time is better :)
ed
dirt
« Reply #189 on: August 04, 2012, 08:38:11 pm »
I think I have created a bigger problem. I plugged in a mouse and keyboard into the computer and now. It only boots the this and stops. It says to insert system disk. I don't have one. I guess I need to start looking for one.
dirt
« Reply #190 on: August 04, 2012, 09:04:42 pm »
i got the game to come up again. wheeew ;D
i'll wait for you so i dont %$^& anything up again.
dirt
« Reply #191 on: August 04, 2012, 10:15:39 pm »
i guess i should have turned it off instead of leaving it on. it froze up so i turned it off. now when i turn it on it just beeps real long over and over and nothing comes up on the screen. :banghead: :banghead: :banghead:
ed12
« Reply #192 on: August 04, 2012, 11:19:35 pm »
hi
dirt
i just got in
have the tester from the warehouse
do me a fav,chk the cmos battery on the mobo,or atleast replace it.....
on my unit from test bench in the warehouse i do not use the pcmia usb card
i hook it right into the mobo's usb,i will explain how to open window's all the way so we can do some basic test's
if u need a rescuse disk let me know i will up-load it in pieces
so all u need do is put it back toghter
ed
dirt
« Reply #193 on: August 04, 2012, 11:50:56 pm »
i just pulled and checked the battery it is at 3.02, so its good. what else would cause the computer to do this? hard drive gone bad?
ed12
« Reply #194 on: August 04, 2012, 11:57:45 pm »
hi
my mind is tilting here
u have a few problem's here
so let's go in a normal manour
just do the ol-boy a fav and replace the bat
then we are gonna take a peek at the mobo setting's
i do believe it is esc on power boot,should bring u to the main mobo bios
something is wack here
let me fire my test unit up
i will post the bios post for u
your's should be the same
ed
dirt
« Reply #195 on: August 05, 2012, 12:20:22 am »
I don't have a new battery. I did swap it with one out of another PC I have and got the same result. Ill get a new battery first thing in the morning.
ed12
« Reply #196 on: August 05, 2012, 12:25:06 am »
hi
....main screen...
on power boot >>delete key<<
this will take u to the bios screen
std setting's as follow's
current date must be current
current time must be current
ide primary >> wdc wd200bb >20meg< this is the hard drive def for your unit..could veri
ide slave  >> none
ide secondary >> master >cdrom<
ide secondary >> slave none
drive a 3.5"
drive b none
video >> ega/vga
halt on >>  no error's
base mem >>640k
extened mem >> 52364
total >> 524288
....advanced....
bios flash protect >> disabled
virus warring >> disabled
cpu l1 & l2 cache >> enabled
quick power on self test >> fast
first boot device >> cdrom
second boot device >> hdd-0
third boot device >> floppy :we can turn this off:
boot other device >> disabled
swap floppy drive >> disabled
boot up floppy seek >> enabled :we can turn this off:
boot up numblock status >> on
that is the first 2 settings page
we skip the third and go to the 4th
ed
ed12
« Reply #197 on: August 05, 2012, 01:26:44 am »
hi
......integerated peripherals......
on-chip primary  pci ide >> enabled
ide primary master pio >> auto
ide primary slave pio >> auto
ide primary master udma >> auto
ide primary slave udma >> auto
on-chip secondary pci ide >> enabled
ide secondary master pio >> auto
ide secondary slave pio >> auto
ide secondary master udma >> auto
ide secondary slave udma >> auto
usb controller >> enabled <<< important >> usb will not work if disabled
usb keyboard support >> disabled
ac97 audio >> auto
ac97 modem >> auto
init display first >> agp : this is 1 of the setting's we change when using a dif video card
onboard ac97 codec >> enabled
onboard lan control >> enabled :we need this for turenne
onboard lan boot rom >> disabled :we enable it to use the lan
ide hdd block mode >> enabled : this is beacuase u may have a cable select mode,and or master/slave setting on your hd setup
that is part 4 of the bios setup
set your's to what i posted and i can better helpp u
ed
Spitfire
  • Last login:August 05, 2023, 07:55:31 am
« Reply #198 on: August 05, 2012, 08:53:14 am »
Hi Ed glad to see u r back n really love ur work. I love this game but am looking to unlock all courses, players, items etc n would love to play online against my friends who also have this game. Is any of this possible if so would love you to explain how?
Eagerly awaiting ur reply thx heaps Ed.
Joe
ed12
« Reply #199 on: August 05, 2012, 12:40:15 pm »
hi
spitfire
and thk-u
answer to your q is a total yes
we remove the dial up
enable the boot lan rom
then we set up a vpn virtuial private network
the best way is static ip-ing,but i cannot really see that hapenning with dchp
so the other way around is to collect most base ip-addy's 224.224.110.0-10
and work it up from there,now i made it sound simple..maybe for a full it guy it is
but i would need a nudgh or 2 in the right way,so i will leave it open to any colsed ip guy's to chime in here..also we re-.cfg herc to know we are going stream on lan
so we add it's driver's and pointer's,up here in the great white north we use rodger's wireless modem's with the chip card,this lock's them into static ip-ing
much like your pay as u go phone's..
as for the player's,u will need the new course set and a player's card
plus loan of an operater's card to load them,un-less u have 1 ?
ed
