Author Topic: Control Panel...am I doing it right?  (Read 1956 times)
bgeveritt
  • Newbie
  • Last login:October 20, 2011, 08:49:34 pm
« on: October 19, 2011, 08:34:41 pm »
My buddy has an old arcade machine, so we've decided to gut it and build a MAME. I've done a pretty good amount of research, and I think I'm ready to start build a control panel. This is my proposed layout:
Basically, it's a 2-player/6-button layout with a coin and start button for each player. I'd also like to include a trackball in the middle (mostly for Golden Tee)
I plan on purchasing the UltraStik 360 (with a hard spring and circular restrictor.) I plan on using the input method of these joysticks, so the buttons will just connect straight to the stick, thus striking the need for an I-PAC.
Since this is my first attempt, I have a few questions:
  • What are the pros/cons regarding using the U360 joytick's input vs. output method?
  • What exactly do I need for a trackball? Do I need an encoder, or can I find a trackball that has a direct USB connection to the computer?
  • Recommended material (wood, particle board, etc.) to use for the control panel?
  • Any glaring issues with my control panel layout/design?
