Author Topic: No contrast adjustment wg 25k7193  (Read 2393 times)
subwyking
  • Last login:September 01, 2016, 11:10:50 pm
« on: October 18, 2011, 12:04:18 am »
Hey folks. I have a wg 25k7193 connected to an arcade VGA 3000.  I have the picture dialed in how I want it with the exception of the contrast. My colors seem a bit washed. I've already done a cap kit, and that really cleared up some of the anomalies I was having. The pot for the contrast adjustment is having absolutely zero effect on the screen.  Any suggestions on how to proceed from here?
Russ
Ken Layton
  • Guru
  • Technician
Re: No contrast adjustment wg 25k7193
« Reply #1 on: October 18, 2011, 12:12:19 am »
Arcade monitors expect a video signal of 2.5 to 5 volts. Computer monitors typically expect 1 volt or less.
Are you getting a strong enough signal to the monitor?
subwyking
« Reply #2 on: October 18, 2011, 07:28:33 am »
I wondered if that may have been the problem. Andy's web page made it seem that Wells Gardner monitors didn't need the stronger signal. Do you think a video amp will clear up the issue?
Russ
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
« Reply #3 on: October 18, 2011, 08:13:57 am »
http://www.ultimarc.com/vidamp.html
You need onna those.
Divemaster is located in the US and sells most of the U-marc product line.
http://arcadeemulator.net/
subwyking
« Reply #4 on: October 18, 2011, 10:06:46 am »
Ok, I put in an order for a video amp, hopefully that clears up my issues!  Thanks for all your input guys!!
Thanks,
Russ
castlesteve
  • Last login:September 12, 2014, 09:10:32 am
  • uh, yea
« Reply #5 on: October 19, 2011, 02:23:41 pm »
sorry, but a video amp is not going to fix your lack of contrast adjustment.  While still a good idea, you need to find the part assoc with contrast.
1st)  id check the pot itself on the control board. look for a hairline crack where the legs meet the pot.
2nd) I know how to fix contrast issues on U2k/u5k boards off hand, but not if a cap kit didnt do it... you'll start have to checking resistors etc in the circuit.
subwyking
« Reply #6 on: October 19, 2011, 08:50:31 pm »
You hit the nail on the head. One of the legs had a cracked Pcb. Thanks!  Now only to find a suitable replacement.
subwyking
« Reply #7 on: October 19, 2011, 09:46:32 pm »
I can't upload a picture of the pot....
subwyking
« Reply #8 on: October 19, 2011, 09:48:52 pm »
Hmmmm....  Well it's a 10k ohm pot that sticks up from the PCB. Can anyone point me to a suitable replacement part from radio shack?
ed12
« Reply #9 on: October 19, 2011, 10:29:32 pm »
small white 1 or black ?
either, there should be room in the :land's: for another size pot
ed
subwyking
« Reply #10 on: October 19, 2011, 10:33:15 pm »
Small white one.
boardjunkie
« Reply #11 on: October 20, 2011, 08:28:14 am »
Oh....I was reading that as a lack of usable range on the contrast control. Anyway....you still need the video amp.
subwyking
« Reply #12 on: October 21, 2011, 08:22:45 am »
Replaced the pot with a Radio Shack part, and it works like a charm!  Thanks for your help guys!!  I'll let you know what sort of improvement I get with the video amp.
Thanks,
Russ
