Author Topic: Simple spinner with optical mouse + a round plate (HDD)  (Read 7051 times)
nordemoniac
  • Weee! Hahaha...
« on: October 13, 2011, 07:30:06 am »
Hi!
I'm thinking of trying out a new spinner project. This is supposed to be a low-cost/no-cost project.
Everyone can find a optical mouse laying around which they are not using. How about "inverting" the use of the mouse. Have the mouse stationary, and move the mousepad instead? F.ex. using a harddrive plate (works well as a fly-wheel) from a harddrive, and mount the mouse so that the optical sensor is hitting the outermost part of the harddrive plate? In theory the mouse would move a bit up or down when doing this (because it's a disc rotating), is that a problem? Is it possible to restrict the mouse to only go perfectly right or left? Anyways, 90% or more of the movement will be sideways.
This is just an idea I'm throwing out there. I need some opinions.
A "mouse" which will be perfect for this project is the finger mouse from dealextreme
Re: Simple spinner with optical mouse + a round plate (HDD)
« Reply #1 on: October 13, 2011, 07:54:08 am »
Since a spinner would really only be driving 1 direction, even if you get a slight drift in the other direction, it won't matter because Mame won't be using that direction anyway.
Cool idea. I'd like to see how it turns out.
RetroBorg
  • Last login:September 15, 2025, 06:25:47 am
« Last Edit: October 13, 2011, 08:40:48 am by RetroBorg »
« Reply #3 on: October 13, 2011, 08:53:52 am »
nordemoniac
  • Weee! Hahaha...
« Reply #4 on: October 13, 2011, 08:54:52 am »
Thank you! Nice inspiration for my hack!
Seems like I must get better in searching the forums.
Still new around MAME, but me and a friend is planning to build a cabinet (on budget). That's why I'm thinking about a solution for a spinner. What's arkanoid without it?  ;)
Btw: Supported the site by buying the book :)
Will post here when I get further in the project.
Green Giant
« Reply #5 on: October 13, 2011, 10:49:27 am »
And this one:
http://forum.arcadecontrols.com/index.php?topic=113528.msg1206395#msg1206395
 :D Didn't expect to see my crude mock up used as an example this morning.
I thought by definition a crude mock up must utilize cardboard.
That is more like an early revision.
Toxic Arcade, my first build
« Reply #6 on: October 13, 2011, 11:10:24 am »
Meh. I just threw together something from the extra crap I had laying around the garage. I was all out of cardboard at the time. ;)
