Author Topic: overscan problem  (Read 1824 times)
jackiabu
  • Last login:May 18, 2025, 02:29:49 pm
    • http://jackiabu.blogspot.com/
overscan problem
« on: October 12, 2011, 09:56:46 am »
Hi
I made a VGA cable SCRAT TO instructions. I plugged in television, there is a problem. Be default my TV needed little adjusting. Some games missing part of picture, overscan or even underscan (image not strecthed enough).
 , A video card that I use is ARCADE VGA 2,my tv is gurnding 21'.
 Does anybody have any solution?
Thanks in advance
apfelanni
  • Last login:February 18, 2019, 01:55:28 pm
Re: overscan problem
« Reply #1 on: October 12, 2011, 02:08:01 pm »
check the sticker on the rear side of the tv . u will find modell and chassistype if it is a grundig . gurnding ?
jackiabu
« Reply #2 on: October 12, 2011, 03:53:56 pm »
It does not matter which model of television, because I  replacing A professional monitor, and still have the same problem.
 Published postures and here you can see it, thanks anyway
« Last Edit: October 12, 2011, 03:55:47 pm by jackiabu »
