Author Topic: Anyone Stuff a Makvision 27" Tri-mode in an MK cabinet  (Read 4087 times)
ctozzi
  • Last login:November 24, 2022, 01:05:42 pm
« on: October 03, 2011, 11:03:50 pm »
Does it fit, and does it mount on the factory mounts ? Any pictures would be great. i'd like to see the windows desktop as well to see if it's blurry or crisp and clear like an LCD.
Chris
Current Cab's
Dedicated Killer Instinct 1
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
MonMotha
Re: Anyone Stuff a Makvision 27" Tri-mode in an MK cabinet
« Reply #1 on: October 03, 2011, 11:49:36 pm »
A 27" should fit, but the factory monitor mounts will either need to be modified or new ones constructed to accommodate the larger size.
darthi8nt
  • Newbie
  • Last login:December 16, 2011, 05:33:44 pm
« Reply #2 on: October 04, 2011, 01:03:54 am »
I put a brand new one in a Big buck hunter cab and didn't have to change anything except the power plug ends. Molex type.
MonMotha
« Reply #3 on: October 04, 2011, 03:41:48 am »
IIRC, Big Buck Hunter is designed for a 27".  MK is designed for a 25".
killerinstinct
  • Last login:August 28, 2021, 11:24:17 am
« Reply #4 on: October 05, 2011, 09:29:30 am »
Hi ctozzi,
Here in a dutch forum someone showing his cab ,
the guy got a makvision 27" in he's cab.
http://www.gameroom.be/forum/viewtopic.php?f=19&t=7873
« Last Edit: October 05, 2011, 09:39:27 am by killerinstinct »
ctozzi
« Reply #5 on: October 05, 2011, 09:51:03 am »
thanks for the pictures, I wonder if it's a direct bolt in or if anything needs to be modded to fit ?
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
killerinstinct
« Reply #6 on: October 05, 2011, 01:58:49 pm »
i don't know,
I mailed the person and ask it , I am also dutch person.  :)
If ill get an answer back Ill post it here for you.
« Last Edit: October 05, 2011, 02:01:49 pm by killerinstinct »
McCarron
  • Last login:May 14, 2012, 11:30:16 am
« Reply #7 on: January 12, 2012, 11:16:16 pm »
Chris did you end up getting a Makvision 27"? I am closing to pulling the trigger on one but it's fit into my MK2 cabinet is the only thing holding me back.
ctozzi
« Reply #8 on: January 12, 2012, 11:17:21 pm »
i got the 25" for my MK1 the image is absolutely gorgeous !
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
McCarron
« Reply #9 on: January 12, 2012, 11:19:54 pm »
Wow quick response! How was the fitment? Easy install with no modification of the mounts?
My monitor is fairly crappy with a lot of burn in, and needs to go.
ctozzi
« Reply #10 on: January 12, 2012, 11:22:50 pm »
bolts right in with the mounts in the cabinet, zero modification needed, make sure you order the power cord to save the frustration. Its a flat screen with an included bezel to close the gap around the rounded plastic bezel in the cabinet now. I just put some tape on the back of the new bezel to hold it to the monitor. Whatever you here about makvision is crap, it's the nicest picture of any of my 9 cabinets.
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
RejectedManiac
  • Last login:January 07, 2019, 08:27:01 pm
« Reply #11 on: July 09, 2012, 08:51:11 am »
Not to start bring up an old topic but if that's a 27" MakVision in there it looks like it fits in there perfect! In the German thread that is.
ctozzi
« Reply #12 on: July 09, 2012, 09:09:13 am »
it's the Makvision 24.8" tri mode.
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
RejectedManiac
« Reply #13 on: July 09, 2012, 09:13:07 am »
In the German thread I translated he says that it's a 27" Makvision ???
ctozzi
« Reply #14 on: July 09, 2012, 09:14:20 am »
your right, I thought this was a thread i started. Sorry bro
Current Cab's
Mortal Kombat 1,2,3
Terminator 2
Rampage WT
WWF Wrestlemania
MAME MK1
Zelda Theme Bartop
RejectedManiac
« Reply #15 on: July 09, 2012, 10:10:09 am »
It's cool. No worries. The 27" he has in there actually looks like the viewable area might be 25". I know the 29" Makvision's have a 27" viewable area.
