Author Topic: LEDBlinky & Other Emulators  (Read 4110 times)
Necro
  • Last login:December 31, 2025, 03:36:17 pm
« on: October 03, 2011, 09:30:26 pm »
Anyone successfully get LEDBlinky working with other emulators in MA?  If so, how?  Having serious issues getting it to work while leaving it configured to work with MAME as normal (which works fine).
So far tried running LEDWiz via command line from MA with just a single emulator name as the command line to light the proper default controls and I tried a bat file to pass a lwax to the controller when the emulator is started.  Still no go - led's stay in their current state.
arzoo
  • Last login:July 05, 2026, 11:11:48 pm
  • Robots WILL kill you.
    • LEDBlinky
Re: LEDBlinky & Other Emulators
« Reply #1 on: October 05, 2011, 08:58:03 am »
Hi,
Turn on the Debug Log and Verbose options (LEDBlinky Misc Options tab), then run through some of the senarios you've tried. Email me the debug.zip file (in the LEDBlinky folder) and I'll take a look.
Robots will kill you.
Arcade Addiction
