Author Topic: [SOLUTION] Certain MAME ROMS won't work unless Long Path enabled.  (Read 5783 times)
Necro
  • Last login:December 31, 2025, 03:36:17 pm
The specific game I problem solved enough to say it definitively occuring with is Gauntlet 2p, rev 6 (gauntlet2p) on Mame 0.136 with vmame64.exe.
The game runs FINE when launched using the same command line that MA should be passing from a command line/box/whatever.  From MA, just sits at a black screen.
So...few things - is there a way to get feedback on what's going on 'behind the scenes' with MA so I can see what's causing the issue?  As it is now, I have nothing to even work from.
There's a number of other games that do this as well...just go to a black screen.  I was figuring it was bad dumps/unworking games but it's just too frequent to be sheer coincidence.  I think something's screwed up for certain games and I'd like to figure out why...that and I want the damn gauntlet 2p working on my cab.
Looks like someone is having similar issues (or did) here: http://maximusarcade.com/phpbb/viewtopic.php?f=3&t=2193
Any ideas anyone?  ANything?  This seriously sucks.
Edit:
So...seems the default of 'short' paths doesn't work for all MAME roms - make sure to set that to long or you'll have issues as I did.
One step closer to 'final'. :)
« Last Edit: October 02, 2011, 05:17:56 pm by Necro »
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
Re: [SOLUTION] Certain MAME ROMS won't work unless Long Path enabled.
« Reply #1 on: October 02, 2011, 09:05:54 pm »
Do any of the "VS." games work for you?  I tried your idea and it didnt make a diff for me.  Im running 0143 all roms updated 32bit version.
Necro
« Reply #2 on: October 03, 2011, 12:47:50 pm »
Hrm.  I don't really like them (don't see the point) but I'll try tonight and see if they do.  I'm running 0.136 now and getting it setup with that - not sure if I'll swtich yet as I don't see the benefit.
