Author Topic: how do i get the coin mech to interface with my pc?  (Read 4229 times)
yup
  • Last login:February 26, 2004, 02:31:15 pm
« on: September 13, 2003, 05:09:48 am »
yeah, i'm a newb. as far as being on the board and when it comes to making arcade stuffs. any help whatsoever would be appreciated. thanks
Totallyout2lunch
  • Last login:July 14, 2008, 01:15:43 pm
  • Tempory nOOb
    • Tree House H.Q.
Re:how do i get the coin mech to interface with my pc?
« Reply #1 on: September 13, 2003, 07:11:17 am »
The way I thought that I would do mine is by hooking up the coin mech to the IPac and route the cable to insert coin switch on MAME...
Is that the correct way you Arcade Gurus...
Today I marched us to the edge of the abbyss...
Tomorrow we go Forward!
Windows leads to anger,
Anger leads to hate,
Hate leads to Linux
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #2 on: September 13, 2003, 07:17:21 am »
You do not interface coin mechs to a pc.  All a coin mech does is sort "good" coins from "bad" coins.  Once a mech has sorted a good coin, the coin then falls down a chute and the coin triggers a switch.  It is this switch that you interface to the pc.
« Last Edit: September 13, 2003, 07:20:19 am by JustMichael »
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
« Reply #3 on: September 13, 2003, 08:54:08 am »
He said it...
There is a switch at the bottom of the coin mech (it's actually part of the coin door, but if you've never seen them seperatly, then it's just at the bottom of where the mech is.)
The wires from this switch should be hooked to your keyboard interface (IPAC, Keyboard Hack, other encoder). The player 1 switch should be connected to the "5" key & player 2 should be connected to the "6" key.
If you have any other Qs, please ask.
I'm not a freak!...
Oh wait...
Yes I am...
SirPeale
  • Green Mountain Man
« Reply #4 on: September 13, 2003, 09:06:45 am »
Covered in the FAQ:
http://www.ecst.csuchico.edu/~darrelld/newbie.html#Coin Door
nb: there have been a lot, and I mean a lot, of basic questions being asked lately.  Shouldn't we be referring n00bs to the FAQ when this happens?
yup
« Reply #5 on: September 13, 2003, 01:49:35 pm »
ok ok....the coin goes into the slot, if it's accepted, it hits a long type pin dealie all the way at the bottom, which i'm assuming triggers this switch. i guess my question would be, would activating the coin mech be worth the trouble? cause wouldn't i have to take apart the keyboard, find out exactly where the the '1' and '2' buttons are mapped, and then wire the coin mech to the keyboard? maybe i'm still misunderstanding this whole process. btw i'm using an xarcade joystick
BobA
  • What Me Worry?
« Reply #6 on: September 13, 2003, 02:03:39 pm »
You would just connect the coin switch in parallel with the coin button on your xarcade.  No keyboard hacking required as your xarcade already provides the interface.
BobA
