Author Topic: joystick question  (Read 1682 times)
MiKman
  • Last login:September 15, 2025, 07:58:44 pm
  • Blah
joystick question
« on: September 12, 2003, 11:23:11 am »
Would a wico balltop shaft fit into a Happ controls joystick base?  Are all (well most) joystick shafts the same diameter?  Length isn't really important, it will just sit higher/lower right?
Thanks,
MiKman
« Last Edit: September 12, 2003, 11:23:57 am by MiKman »
RandyT
  • Last login:Yesterday at 02:39:45 pm
    • GroovyGameGear.com
Re:joystick question
« Reply #1 on: September 13, 2003, 09:45:17 am »
Most are not interchangable.  I can't answer this one positively, as I haven't tried what you are suggesting.
But my guess is that something would need to be modified, even if the O.D. of the shaft was correct.  There are spacers and grooves for the "e" clip that play a big role in holding everything together.  If they are out of place or the wrong size, you'll have problems.
RandyT
Homebrew
  • Last login:May 03, 2012, 09:48:55 pm
« Reply #2 on: September 13, 2003, 12:17:39 pm »
The wico 4" balltops will fit the P360 base.  In some cases(at least mine) you may need to add a washer under the e-clip to get the tension right.  See my last post in this thread:
http://www.arcadecontrols.org/yabbse/index.php?board=10;action=display;threadid=11365
I've linked a couple places that sell balltop replacements as well as some previous threads on the subject.
-Kevin
spidermonkey
  • Bombjack junkie
« Reply #3 on: September 14, 2003, 04:00:12 am »
"Sinistar has bad breath"
MiKman
  • Blah
« Reply #4 on: September 14, 2003, 11:42:46 am »
Thanks for the info guys.  Has anyone ever seen these 4 ways before?  They look pretty slick.
http://cgi.ebay.ca/ws/eBayISAPI.dll?ViewItem&item=3242095973
