Author Topic: monitor bezel out of mdf  (Read 7126 times)
nnndoh
  • Last login:February 27, 2012, 04:59:27 pm
« on: September 17, 2011, 07:12:33 am »
Don't know if anyone has tried it yet, but as a carpenter i can say, its easy to make one.
if you want i can put up a photo how to trace the shape of the monitor onto the wood
very easy  ;)
Re: monitor bezel out of mdf
« Reply #1 on: September 17, 2011, 10:15:07 am »
I humbly request more images!  Thanks!
« Reply #2 on: September 17, 2011, 11:41:45 am »
Yes, please do.
nnndoh
« Reply #3 on: September 18, 2011, 07:45:40 am »
allright, firstly excuse me for my english
i do not know english measurements and the names of some tools i used
But for MDF i went to the local do it yourself store where i bought 1 sheet of mdf 600 x 1200 mm , 4 mm thick
its around 5 euro's
then i meassured my display screen and added 9 mm on all the sides.
When i cutted it out i glued  some support wood wich i made 5 mm angled
backside
then with some trial and error i meassured the insides and took a piece of mdf with some over overlenght above the bezel
then i secured it with 2 little nails so i can trace the shape of the monitor on that small piece of mdf
to get a good result at the corners use this piece tfor a new one because its kinda difficult to get good meassurements from the top of the bezel to the monitor screen.
then i sanded everything smooth and rounded the sharp edges.
now ii am ready to fill any unwanted cracks and small errors, sand it again and paint it black
hope this info will help all to get the same cool result as i have
Unstupid
« Reply #4 on: September 19, 2011, 03:57:15 pm »
It would probably be easier if this was done with a compass.  ;)
nnndoh
« Reply #5 on: September 20, 2011, 03:44:46 pm »
i looked up compass on google and i am really puzzled how you use such device to trace a monitor on the mdf
what you see on that pic was an example cause the bezel ( behind it ) was allready finished
but it has the wrong demensions for my hellomat bezel.
Turvey
  • Last login:Yesterday at 08:29:51 pm
« Reply #6 on: September 20, 2011, 05:14:55 pm »
I believe Unstupid is referring to 'A set of compasses'...
as opposed to 'A compass'...
Sorry, I had a pedantic maths teacher and it's something that's just stuck with me  :-[
Unstupid
« Reply #7 on: September 20, 2011, 05:31:08 pm »
Nope just one.  On your compass set the distance from your screen to where you want to draw the line.  then lock the compass so that distance cant change. Then drag the metal tip along the glass and transfer the offset to the board with the pencil side.
Turvey
« Reply #8 on: September 20, 2011, 06:04:49 pm »
Sorry.
I had a couple of pics in my post but they didn't show for some reason.
 A COMPASS SET is what you use to draw a circle with and which would helpful here and A COMPASS is what you use to find North which probably wouldn't  ;)
« Reply #9 on: September 20, 2011, 07:06:33 pm »
Sorry.
I'm with Unstupid.
  • Last login:September 15, 2026, 08:48:46 am
« Reply #10 on: September 20, 2011, 08:57:06 pm »
Useful tutorial, thanks.
TopJimmyCooks
« Reply #11 on: September 20, 2011, 09:20:33 pm »
In woodworking terms the technique of marking a piece of wood to be cut to fit an irregular surface is called scribing.  a compass is commonly used but the block of wood is a good idea to keep from scraping the monitor glass with a metal compass.
