Author Topic: Can Yall HELP????  (Read 2826 times)
Mooters
  • Last login:April 08, 2005, 02:48:35 pm
  • I Hate Mondays, I LOVE MOZZY (MOZILLA)
Can Yall HELP????
« on: September 09, 2003, 10:59:48 pm »
I am probably not looking in the right spots :-\
but if i overlooked it (i cand spell worth a flip)
point me in the right direction.
Is there a way to use windows joysticks with MAME?
mine is a generic usb game device according to windows.
I use XP if that helps :) (I Hate Windows >:()and all the stuff i tryed so far doesnt work.
Thanx, Code_3005 ;)
« Last Edit: September 09, 2003, 11:01:30 pm by code_3005 »
The Game Is NEVER Over!!!
SirPoonga
  • Puck'em Up
  • The Bears Still Suck!
Re:Can Yall HELP????
« Reply #1 on: September 10, 2003, 12:14:54 am »
yes, enable joystick support in mame.   Look in the ini file.
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
« Reply #2 on: September 10, 2003, 12:16:57 am »
You should most likely be able to use it. (if windows is seeing it.)
Have to enabled the joystick in the MAME ini file? Also, have you reassigned the buttons as necceary?
I haven't done it in a while, I'm sure someone here can tell you the exact setting, probably set the Joystick option to "auto" or to "1" I can remember the parameters... ???
Smack
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
jhsmith321
  • Last login:December 26, 2007, 09:45:27 am
  • I dig the skin I
« Reply #3 on: September 10, 2003, 12:21:13 am »
I thinks that updating the direct-x drivers will help!
u_rebelscum
  • You rebel scum
    • Mame:Analog+
« Reply #4 on: September 10, 2003, 03:10:00 am »
code_3005, if you run into basic questions like this one, easyemu and mame.net FAQ are great spots to start.
Not that asking is a bad thing on this forum, but sometimes it can be quicker and clearer if you look at the about two links first.
FWIW,
"auto" is for dmame (dos mame), "1" is for mame (win mame and mame32).
Robin
Knowledge is Power
EggZilla
  • Last login:January 17, 2004, 04:44:20 pm
« Reply #5 on: September 11, 2003, 10:51:40 pm »
Actually, we may be overanalyzing the problem. If you're using MAME 32, which I would assume you are since it's typically what most folks start with, there are check boxes to turn on gamepad support in the interface.
Here's how to do it:
1. Plug the controller into your PC before you fire up MAME.
2. select Options, Default Options, and then click on the Controllers tab. Click the box where it says "enable joystick input"
3. Then, you may have to also enable the controller for each individual game. To do that, right click on the game, again select "Properties", and again go to the "controllers" tab and check the box that says "enable joystick input".
Hope this helps!
Like a bird on a wire,
  Like a drunk in a midnight choir,
   I have tried, in my way,
      To be free.
          - Leonard Cohen
hyiu
    • www
« Reply #6 on: September 12, 2003, 03:40:33 pm »
ok.... I suddenly think of something....
if you're using XP... maybe you've the same situation...
I start the machine.... and it sees the joystick in ctrl panel and everything....
tested it in property and it works...
started Mame32... the joystick option is checked....
but the joystick and buttons do NOT work....
ok... now... quit Mame32.... (exit that program...)
but DO NOT REBOOT !!....
now... restart Mame32.....
Joysitck and buttons now work....
I donno why... but restarting Mame32 without rebooting machine will solve the pblm....
hope it helps... (I'm using XP too...)
Mooters
« Reply #7 on: September 12, 2003, 06:01:20 pm »
Hey i got it to work, by the way im using MAME 0.73,
I just need a joystick config file for my joystick
its a psx pad with a USB converter
i just need help with mapping out the buttons
if you can help i will appreciate it.
Thanx
    Cody
jerryjanis
  • Last login:Yesterday at 03:26:18 pm
  • Skate or Die!!!
    • Jake's Joystick
« Reply #8 on: September 14, 2003, 07:04:58 am »
The quickest way to remap the buttons in Mame is to press "tab" while you are in the game.  A menu will come up where you can change the button settings among other things.
