Author Topic: JPac control problem  (Read 1685 times)
jurulz
  • Last login:February 21, 2020, 04:18:28 pm
« on: August 24, 2011, 10:05:19 pm »
Hi,
I'm having problems with the j-pac.
first of all. I connected the j-pac using ps/2 cable with converter usb to ps/2 converter on a usb port of my computer (on the j-pac i've plugged the cable to the pc/kb connector). Because it doesnt work on the ps/2 ports. I connect my keyboard using a ps/2 to usb converter on the KEYBOARD connector
the j-pac only works with:
The 2 joysticks
Start for player one and two
and the High punch for second player
My pc setup:
Acer pc with windows XP 32 bits
Sempron Processor 3800+
ArcadeVGA 3000
Arcade:
It's a mortal kombat transformed to mortal kombat 3.
the control panel is the original without modification and work with jamma games....
I'm really having big time with the j-pac. Can you help me?
Re: JPac control problem
« Reply #1 on: August 24, 2011, 10:31:17 pm »
Have you tried emailing Andy at Ultimarc? He's pretty good at tech-support for his products.
MonMotha
« Reply #2 on: August 25, 2011, 01:45:34 am »
Ultimarc explicitly has recommended against the use of PS/2 to USB converters in the past.  The JPAC actually supports USB natively; you just need the special cable.  You might try that.  Otherwise, it sounds like you should check your common ground lines to your switches.
