Author Topic: Options for making your own wireless Arcade Stick for PS3  (Read 2319 times)
Essential J-Balls
  • Last login:February 21, 2012, 09:06:59 pm
« on: August 23, 2011, 09:21:53 pm »
Just curious what my options are.... the only option I can find is toodles axisadapter but I don't have any controllers that are compatible nor have I had luck finding any.   From everything I've read I'm at a loss for how to build a wireless stick without the axisadapter.  Can I solder wires directly onto the ps3 controller pcb? I've tried searching for a schematic but haven't found one.  I have not yet taken apart a controller to see if the button connections are actually labeled with the name of the button.   Any help on this is greatly appreciated, thank you.
equlizer
  • Last login:November 17, 2019, 02:56:48 am
  • All your base are belong to us
Re: Options for making your own wireless Arcade Stick for PS3
« Reply #1 on: August 27, 2011, 04:13:15 pm »
Try and find a used sisaxis controller and take it apart and solder to the points on the pcb.  Get some knar wire 30-32aug for soldering.
Eddie_Brock
  • Last login:February 26, 2014, 12:00:34 pm
« Reply #2 on: August 28, 2011, 02:20:19 pm »
I've taken two DualShock's apart to add LEDs, and I can tell you that the PCBs aren't labelled at all.
I'd suggest looking online for a proper schematic. Be careful if you have to reassemble, the Trigger buttons are awkward to get all in and functional.
