Author Topic: Bright things cause dark band across screen  (Read 1275 times)
crashwg
« on: August 22, 2011, 09:40:27 pm »
I've got this TV that might end up in an arcade machine if I can fix this little issue.  The problem is on mostly dark screens where there is bright spots like words or other bright objects.  When there is such a bright thing on the screen it is always accompanied by a band of darkness that is the same height as the bright thing and spans from left to right.  I'm not sure if my description is clear enough so here's a M$ Paint depiction.  What's the fix oh great monitor gurus?
By the thorax and abdomen
Lemme say it again
In my land of pretend
I use bees as a mf'n pen
lilshawn
  • Last login:March 16, 2026, 03:44:11 pm
Re: Bright things cause dark band across screen
« Reply #1 on: August 23, 2011, 07:39:32 pm »
you might have an issue with the B+ being a little low....
but more likely you have a capacitor in around the flyback that is getting weak.
the power used to drive the picture from black to white needs to be nice and steady and not vary. if it varies, the you get a weird banding or sometimes in extreme cases you get a screen that starts to collapse in on itself (get smaller) when it gets bright. usually it's a failing capacitor but could be a B+ going all over the place.
