Author Topic: Player 2 Using a Gamepad  (Read 1985 times)
Woodshop Flunky
« on: August 15, 2011, 10:38:45 pm »
I've got a U360 and an iPac on my son's cabinet.  The control panel works fine like this for player one.  However, if I plug in a USB gamepad, then the gamepad will work, but the CP controls are all messed up.
Is there a way to force Windows/MAME to recognize the USB U360+iPac as player one always, and the gamepad as player two always?
Thanks.
Woodshop Flunky
Re: Player 2 Using a Gamepad
« Reply #1 on: August 15, 2011, 10:55:56 pm »
A little more specific...
When I plug in the gamepad, the gamepad controls player one fine.  The U360 stick, however, now controls player two movement, and the CP buttons still affect player one.
Thanks.
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #2 on: August 15, 2011, 11:01:50 pm »
I you are running XP an go to controllers in the control panel you can pick one of the devices as you preferred device and it will always be p1
Woodshop Flunky
« Reply #3 on: August 15, 2011, 11:41:50 pm »
I'm using Windows 7 and haven't seen an option like that.
I remember reading something about hard coding each controller with a unique USB identity.  Is this an option?  ...and how? :)
TopJimmyCooks
  • Last login:May 11, 2026, 08:21:16 pm
« Reply #4 on: August 16, 2011, 09:18:53 am »
Search for Drventure's controller remap app, it was specifically for that problem, but it may have been for xp rather than 7.
Woodshop Flunky
« Reply #5 on: August 16, 2011, 09:30:01 am »
I found this thread.  I'll have to check it out and see if it does what I need.
http://forum.arcadecontrols.com/index.php?topic=108767.0
