Author Topic: WTS: 2 player CP with 2 optical rotaries, trackball, 7 buttons per player  (Read 1197 times)
cptnwhlz
  • Last login:November 21, 2016, 11:02:27 pm
Album: http://imgur.com/a/kTVuC#SuBHR
-7 button layout for each player with an optical rotary joystick each along with a start and coin button.
-trackball with 3 buttons that are set to mouse 1, 2, and 3.
-empty spots for spinner/4 way joystick and extra admin buttons.
-Top of the control panel is plastic coated professionally and has been professionally t-moulded. The rest of the box is pretty rough (I made the bottom part as a makeshift piece that ended up being permanent.
-The controls are interfaced with a 2 player Ipac (ps/2 connector: most inputs at once) and an optipac for the trackball and optical rotary joysticks
-Controls have connectors so you can make adapters for consoles or whatever else you want to do. I may still have an adapter to make player 1 work on 360, but I would have to look for it. Think of it as a bonus.
Some disclaimers: The bottom of the box is round and hand cut. The top has a few tiny specs of white spraypaint overspray. I may be able to get it off my self. There is also a small chip on the top near player 2. There are NO WIRE HARNESSES FOR THE ROTARY ON THE JOYSTICKS. This is just for the spinning of the joysticks for games like ikari warriors. 99% of games are unaffected. The wire harnesses are only a few wires and the spots are open on the optipac, I just lost them and never played optical rotary games. Easy fix.
Please don't hesitate with questions! I want to downgrade to something simpler and more portable. I want 2 Tournament edition sticks that I can bring to friends houses (xbox 360) or money.
