Author Topic: Happ 2-1/4" Trackball template  (Read 2960 times)
mytymaus007
« on: August 11, 2011, 08:46:31 am »
I have a tight fit need to know the measurment of the cutout and mounting plate for a 2-1/4" Happ Trackball  :cheers:
milkit
  • Last login:June 28, 2014, 09:14:33 pm
mytymaus007
Re: Happ 2-1/4" Trackball template
« Reply #2 on: August 11, 2011, 12:12:10 pm »
http://na.suzohapp.com/trackballs/55110100m.htm
Thanks Do you know if anyone has a template to layout before cutting
milkit
« Reply #3 on: August 11, 2011, 05:18:21 pm »
not that im aware of, but you could draw one with a ruler based on those dimensions easy
Hoopz
  • Intellivision Rocks!
« Reply #4 on: August 11, 2011, 07:11:38 pm »
mytymaus007
« Reply #5 on: August 11, 2011, 09:26:11 pm »
http://forum.arcadecontrols.com/index.php?topic=10627.0
Did you try that one?
yes i did not sure how to read that one im assuming the dotted line is the cut out if so let me know theni would be able to use that one
