Author Topic: MAME key binding question  (Read 4104 times)
jimmy2x2x
« on: August 04, 2011, 07:23:51 am »
when mame is running, open tab menu, select control to modify
and I want to ADD a key to the existing bound keys, not overwrite it
pretty sure you can do it, cant remember how ;)
BobA
  • What Me Worry?
Re: MAME key binding question
« Reply #1 on: August 04, 2011, 08:26:39 am »
You hit enter to change the key.  The next key you hit will be assigned. If you hit enter again you can add a key to the one you first put in.  If you hit enter again you can add a third key.   If you mess up just exit the menu and come back and hit enter and you will be able to add a single key again.
jimmy2x2x
« Reply #2 on: August 04, 2011, 08:44:35 am »
Thank you Mr.Fett
