Author Topic: IPAC/T-Stik Problems  (Read 1615 times)
atomaka
  • Last login:April 10, 2004, 10:42:24 am
  • Arcade Newbie!
    • Who is Andy?
« on: September 06, 2003, 10:59:02 pm »
Hey all.  I finally got around to wiring my control panel and ran across a slight speed bump.  All of the buttons will put in the correct keyboard presses as they should. However, if I use the joystick, I click it once, and the key associated with that direction will continually "be pressed."  I tested this in notepad after installing the IPAC software.  If I push left on joystick player one, the cursor will just continually go left as long as it can (and assumeably would go further if it could)
This occurs with both joysticks and happens no matter what slots on the IPAC the joystick switches are connected to.  As far as I know, the joysticks are wired properly (just like the rest of the buttons).
Any input would be greatly appreciated.  Thanks!
~ Andrew Tomaka
:: www.whoisandy.com
:: www.tomler.com
Birdtales
  • Last login:October 06, 2020, 10:00:31 am
  • You won't like me when I'm angry.
    • Birdtales
Re:IPAC/T-Stik Problems
« Reply #1 on: September 06, 2003, 11:08:47 pm »
MAke sure you wired to the N.O. (normally open) contacts on the microswithces and not to the N.C. (normally closed).
Coming Soon
JustMichael
  • Mmmmm!! Cheesecake!!
« Reply #2 on: September 06, 2003, 11:09:58 pm »
It sounds like you do NOT have it wired correctly.  I would suggest putting the ground wires to the COM tab on the microswitches and the input wires to the NO tab on the microswitches.  Do not use the NC tab on the microswitches.
« Last Edit: September 06, 2003, 11:12:15 pm by JustMichael »
Smack
  • Last login:May 07, 2013, 11:40:41 pm
  • Who changed my avatar?
« Reply #3 on: September 07, 2003, 04:40:00 pm »
If I recall correctly, the T-sticks wiring tabs are opposite from the regular happs ones. You have to wire to the outside connectors.
Smack
Never Let Donkey Kong Use Your Toilet.
(We're talkin' big processed brown bananas...)
Somebody out there stole my sig! LOL
atomaka
  • Arcade Newbie!
    • Who is Andy?
« Reply #4 on: September 08, 2003, 12:43:22 am »
Smack
I am pretty sure this is the case.  Thanks for all the help guys!
~ Andrew Tomaka
:: www.tomler.com
RedSquirrel
  • Last login:September 18, 2003, 12:07:55 pm
« Reply #5 on: September 08, 2003, 05:30:40 pm »
Smack
yeah i had this problem too with my t-sticks! took me ages to work out, but now all works fine  :)
