Author Topic: Extending Controller Cords?  (Read 1022 times)
Hellfromabove
  • Last login:January 08, 2020, 05:45:41 pm
  • Soundwave Superior, Constructocons Inferior!
« on: September 06, 2003, 09:03:28 pm »
Hey guys I am building an arcade stick for a friend but the cord on the PCBs I am using are too small. I was wondering, could I splice the wires from the cord and extend them? I mean is the response of the button spress going to be the same or will it lag? Also if that works could I use a converter on it? I mean I used a extension cord and then a converter and I noticed a lag, I mean I REALLY noticed it. I was wondering if the same thing would happen. Any information would be great. Thanks in advance. Thanx.
-See Ya!!!
Jakobud
  • Last login:May 25, 2026, 02:04:14 am
Re:Extending Controller Cords?
« Reply #1 on: September 06, 2003, 09:22:56 pm »
What cords are you referring to?  The wires that go from the buttons and joystick into the encoder?  Or the cord that goes from the encoder to the computer?
hooded_paladin
  • Last login:November 06, 2013, 08:59:01 pm
  • Finch! hahaha
« Reply #2 on: September 06, 2003, 09:47:43 pm »
electrons travel at the speed of light.  In most cases, you can extend wires without noticing a thing.
Did you try using it with the converter but not the extension cable?  (When you say converter, I think you mean you're doing a playstation hack and using a PSX->PC converter, or something similar)  Some converters are naturally laggy, and extending wires shouldn't make much of a difference.
*edit* as in, get a different PSX converter if that is the case
« Last Edit: September 07, 2003, 12:04:20 am by hooded_paladin »
There is SO a spoon.
Hellfromabove
« Reply #3 on: September 06, 2003, 11:24:36 pm »
OK thanks for the help guys. I hope this works. Thanx.
-See Ya!!!
