Author Topic: I-PAC Wiring Question  (Read 1595 times)
juxtapose519
  • Last login:July 25, 2011, 04:39:17 pm
« on: July 25, 2011, 04:00:50 pm »
This is probably a scrubby question, but I know very little about wiring and I've looked everywhere and can't find an answer.
If I were to wire two inputs to the same connector on an I-PAC, would they both function?
For example, if I were to create two sets of controls (one with an 8-way joystick and another with a 4-way joystick), could I wire both joysticks to the same four connectors? Or could I connect both a button and a coin door to the same coin connector? Or add a second button to the 1-player start connector to use as a dedicated shift button?
I'm not necessarily looking to do these things, I'd just like to know if it's possible.
Re: I-PAC Wiring Question
« Reply #1 on: July 25, 2011, 04:24:23 pm »
Yes, you can hook up multiple buttons to one connector set. Easy as putting a second set of wires in the connector.
If you wanted to get really crazy, you could also hook up a toggle switch to have only one button register at a time. Not hard to do at all.  :cheers:
« Last Edit: July 25, 2011, 04:26:08 pm by Vigo »
juxtapose519
« Reply #2 on: July 25, 2011, 04:39:17 pm »
Sweet, thanks!
« Reply #3 on: July 27, 2011, 10:44:28 am »
Also, check out the videos that I made on how to wire up controls.
http://forum.arcadecontrols.com/index.php?topic=80229.0
There are other useful videos on that topic above as well.
Good Luck!
DeLuSioNaL29
