Author Topic: Custom TRON themed CPO  (Read 6928 times)
jsb98
  • Last login:July 20, 2012, 08:31:05 am
« on: July 24, 2011, 03:29:28 am »
So this is my Tron themed CPO. No, it's not for a Tron cab, I just chose the Tron theme because I like it. Now, I'm going to be playing Mortal Kombat a lot on this cab, but I wanted this neater-looking layout for my buttons. I've labelled them for now so you can see what they would be, but I want to know if you think it should be different. As I haven't made any progress on construction itself (I prefer to plan things like this a lot before actually starting), it's no problem to completely change the control panel. If anyone has any ideas on how this design (both the control positioning and the CPO) can be changed and improved, please speak type your mind. This will be for my first cab and I'd really appreciate feedback. I don't want to mess it up.
EDIT: Come on, I know you're there. Just respond!
« Last Edit: July 25, 2011, 04:27:36 am by jsb98 »
SNAAKE
  • Trade Count: (+29)
Re: Custom TRON themed CPO
« Reply #1 on: July 25, 2011, 07:05:07 am »
background need some blue glowing grid
everything else looks good :burgerking:
Martijn
  • Akira!
    • ModMyBox
« Reply #2 on: July 25, 2011, 01:46:25 pm »
needs a little more tron
how about a grid
jsb98
« Reply #3 on: July 26, 2011, 02:53:19 am »
how about a grid
A grid, then. I'll get on it.
jsb98
« Reply #4 on: July 27, 2011, 05:20:24 pm »
Here's the grid.
SNAAKE
« Reply #5 on: July 27, 2011, 05:29:45 pm »
better :burgerking:
« Reply #6 on: July 27, 2011, 09:25:47 pm »
I think i'd try outlining the solid blue areas instead of having them solid like that. And bits of a contrast color might help.
Woodshop Flunky
« Reply #7 on: July 28, 2011, 12:45:49 pm »
The solid blue is shaded at the edge... it makes it look more like a big button.  I would not use any gradients, and instead use some thin black lines on the inside, or same color blue on the outside.  Martinjn's post shows that there are a lot of smaller lines.
I love the TRON theme... keep at it! :)
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #8 on: July 28, 2011, 01:00:15 pm »
There was a really sweet Tron themed CP I saw on here.  What they did was they used some stencils on the back of some plexi for lines and circles and stuff and then spray painted the back of the plexi black and routered out the channels for the lines.  Then they lit up the lines with LED's and diffused it with some sort of opaque insert.  It looked really, really, f-ing awesome.  You should do that.
wol-nz
« Reply #9 on: July 29, 2011, 09:31:29 pm »
Yes sir ~ Martijn post is beautiful. Inspiring!
I will give TRON a shot and upload my .PSDs. (give me a week or two)
Keep up the work on your art. with some additional photoshop effects like outer glow, pattern shading with soft light properties you will see a remarkable transformation.
Donkbaca
« Reply #10 on: July 30, 2011, 12:06:05 am »
Martijn
  • Akira!
    • ModMyBox
« Reply #11 on: July 30, 2011, 05:37:51 am »
Yep, same here. I dont know how i found that pic, but it inspired me as well. I am even considering changing my latest build into this artwork.
jsb98
« Reply #12 on: July 30, 2011, 08:21:42 am »
Looks to me as though it could potentially become quite expensive. Maybe I should change my theme...
Donkbaca
« Reply #13 on: July 30, 2011, 10:38:57 am »
How do you figure that it would be more expensive? It's the same materials, just need spray on opaque stuff and buy some LEDs. No need for a led controller or rgbs
maumao
  • Last login:September 13, 2024, 05:47:03 am
« Reply #14 on: August 01, 2011, 06:22:02 am »
how about a grid
very nice... vector file is it available for download?
wol-nz
« Reply #15 on: August 08, 2011, 12:27:53 am »
Not sure if there is a vector file available - but if your interested i'm working on a Photoshop raster. All done from scratch in PS CS4
Here's a snippit - I'll make the .psd files available once done.
Sorry to thread jack - but i thought you might like it - since you love TRON and wanted advice [i'll start another thread if you like]  :cheers:
« Last Edit: August 08, 2011, 01:02:32 am by WoLLiEnZ »
Martijn
  • Akira!
    • ModMyBox
« Reply #16 on: August 08, 2011, 08:17:38 am »
Very interested  :cheers:
GonzoDX
  • Last login:September 13, 2011, 07:30:07 am
« Reply #17 on: August 09, 2011, 02:36:01 pm »
I have been working on a Tron inspired (loosely) panel.
Ill just share what I have done. maybe it will help you come up with some ideas.
This is the old version of image that I'm having printed to go under the plexi.
not trying to hyjack. just share Ideas. I took some suggestions off this post already on my art reedit.
« Last Edit: August 09, 2011, 05:30:02 pm by GonzoDX »
