Author Topic: First Build - TV (27" Toshiba CN27H95) or go buy a 21"+ CRT Display?  (Read 1880 times)
elquesogrande
  • Last login:August 21, 2011, 05:01:35 pm
I searched the forums and found a lot of advanced topics, but nothing as basic as this question...
First build here and pretty excited about the project!  I'm trying to figure out whether I should go with a 27" Toshiba CN27H95 that I have or should I pop for a used 21"+ CRT computer display?  (I do not have the electronic know-how to go with an arcade monitor on my first build.)  The TV would go with a Radio Shack RF modulator.
Any help for someone just getting into this addiction would be much appreciated!
Thanks.
Donkbaca
    • Slim built MAME/Xbox cab
RF modulator! That will look like garbage. Use the CRT monitor
abzman2000
  • Last login:August 26, 2020, 06:25:12 pm
  • I LIKE my hat!
from what I can find that tv has component in, if you can get a graphics card that does component out you would be golden, even if you can't that tv should have 2 composite in and one s-video, I don't see why you'd be using an rf modulator with this tv at all
elquesogrande
I've suspected that the RF modulator might not be a good solution - thanks.
