Author Topic: i-pac4 problem  (Read 1388 times)
BigBri
  • Last login:December 15, 2005, 01:23:22 pm
    • Brian Zellinger's Blog
i-pac4 problem
« on: September 05, 2003, 02:28:57 pm »
i don't know how this can be software related, but after i installed xp pro(full), every button and joy seem to sometimes register twice although i hit it once.  so i checked my wiring like 10 times and couldn't find anything that could be causing this.  i then decided to just rip all the wires and start over, testing a few microswitches....only to find that it's still messed up.  it's very annoying when i'm in arcade jukebox trying to que in a tune and it's a chore, know what i'm sayin'?
thanks for your help, my fans
walls83
  • beer is good
Re:i-pac4 problem
« Reply #1 on: September 05, 2003, 02:40:46 pm »
have you went in and checked to see if your buttons are doubled up..? If you go into mame and check the buttons you can check it.
BigBri
Re:i-pac4 problem
« Reply #2 on: September 05, 2003, 02:53:06 pm »
well, i removed all wires and checked one microswitch here, one switch there.  i'm doing one at a time and getting problems.  i can't have 40 bad microswitches
tmasman
  • Last login:January 04, 2024, 03:50:44 pm
  • Hello...
    • My (no so up to date) Home
Re:i-pac4 problem
« Reply #3 on: September 05, 2003, 02:56:26 pm »
If you're saying you're testing the connections over the IPAC, then try testing the switches with just a multimeter... I seriously doubt that your microswitches are bad (at least no all of them).
You might just have a problem with the IPAC. They would probably replace it if that's the case.
I'm not a freak!...
Oh wait...
Yes I am...
grafixmonkey
  • Last login:October 16, 2010, 08:16:50 pm
  • must... tear self... away from... Tron...
    • My graphics/arcade/circuits site!
Re:i-pac4 problem
« Reply #4 on: September 10, 2003, 11:15:02 pm »
and check you're on the NO terminals not the NC terminals...  thought someone had a prob with double presses once and it was cuz of that.  That's bout all I can think of though.
-- See my grafix, circuits and cab on my
-- new arcadey page:  http://www.bkgrafix.net
