Author Topic: sold sold bronx ny /Kortek KTL201MD LCD usb 3m touch screen jukebox or display  (Read 2979 times)
mebronx2000
  • Last login:December 25, 2025, 09:47:47 pm
listed on ebay http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200625383211
new low price will take $100 this is a heavy duty toucscreen plus $40 for shipping thanks  :cheers: :applaud:
$250 plus $40 shipping or can be picked up in bronx ny 10475
this is a 20" multilayer touchscreen will fast response and accurate this is not cheap made like elo this is made for heavy use
This is a lightly used Kortek KTL201MD TFT LCD touch screen display. This is apparently used in some type of Casino game. i was going to use it for a jukebox The screen is 20.1 inches.  This display was used in a test lab environment, and not in public use, so it has not been used extensively. It is in good working condition. touchscreen works great much better than elo  It has two VGA connections and two DVI connections. I used one VGA connection to test this. no scratches on the screen glass. This unit is very heavy so shipping is not cheap. I do not mark a profit on shipping. You pay what it costs me. Here is a bit of info from the service manual. Do the Google search if you want more info:
General Description
• The KTL201MD is a Multi-Layer Display (MLD™) constructed utilizing PureDepth™ MLD technology for displaying multiple images on two planes font and rear.
Native screen resolution is 1680 x 1050. Display depth between front and rear images is 8mm. Data is connected via a single VGA cable, which is daisy-chain
connected to two Scaler boards.
The KTL201MD incorporates integration options for two types of touch screen sensors and controllers – 3M and DigiTech Systems with a USB interface.
This specification does not cover details of the touch systems
Each display plane (front and rear) has independent On-Screen-Display (OSD) control of standard display functions.
The front OSD control incorporates brightness control of the whole module.
The Rear Scaler Board1 is configured to suppress confusion at boot-up, where typically both layers display The same content (clone mode) instead
when boot up resolutions are detected the rear display is set to display no content (clear mode).
Components Features
� Image B’d (Maple_MLD)
• State of the art high performance picture quality design
• Analog RGB (Input /Output)
• Multi-sync capability up to WUXGA resolution @ 60Hz (1920x1200,60Hz)
Compatible standard DOS, VGA, SVGA, XGA, SXGA @60Hz VESA timing
• True color (16.7M) data processing and display driving
• Single control operated & transparent On-Screen-Display (OSD) user interface
• Full control of all relevant display and interface parameters via OSD
• VESA DDC2B compliant (TBD)
• Compatible with VESA DPMS power saving modes(option)
• Form factor: 77mm (L) x 119mm (W) x 13mm(H)
• +12VDC single power: DC power adapter recommended.
• MTBF(Mean Time Between Failure) : 50,000h
• Ambient Operating temperature: 0 to 50°C
• Support to Custom Signal
• Include Frame Rate Converter (Support to TV panel)
• Thermal/Luminance Control(IRPT)
� Panel
1) LTB201MT01
• High contrast ratio, high aperture structure
• Surface Treatment : ARC
• High Transmittance (Color gamut 45%)
• TN (Twisted Nematic) mode
• Wide Viewing Angle
• WSXGA+ (1680 x 1050 pixels) resolution
• Low power consumption
• DE (Data Enable) only mode
• LVDS (Low Voltage Differential Signaling) interface (2pixel/clock)
 :applaud: :applaud:
« Last Edit: July 02, 2011, 04:14:47 pm by mebronx2000 »
Raven..
  • Last login:June 29, 2021, 12:51:50 am
What juke software are you running in the video ?
mebronx2000
e touch  :applaud: :applaud: :cheers:
