Author Topic: Wiring a tweeter help!  (Read 2633 times)
Nacimroc
  • Last login:October 20, 2015, 03:46:25 pm
« on: June 26, 2011, 09:49:43 pm »
Ok, So I got a 10'' sub (8 ohm 250 watt), 2 x 6'' mids (8 ohm 100 watt). Wired them in parallel.  Working fine no problems. I also have installed 1 tweeter i had lying around( not wired up yet). I have no idea of impedance (could check tomorrow) or any other specs.  The amp is a car amp, 200 watt max bridged which is what I am wiring it.
I want to include this tweeter but I need to know what size capacitor, resistor etc to use! Or can I just wire it straight ?  Second question, if its 200 watt max bridged, whats the chances of my blowing my mids that are only 100 watt ?  I would never put it on full blast and would probably set the volume on amp at about 60% and then wire a seperate volume pot in!
« Last Edit: June 26, 2011, 10:06:01 pm by Nacimroc »
mountain
  • Trade Count: (+9)
  • Last login:March 06, 2026, 07:42:38 am
    • Mountain Jukeboxes
Re: Wiring a tweeter help!
« Reply #1 on: June 28, 2011, 10:44:10 am »
Read this, it should help.
Power alone usually wont blow a speaker, distortion from under powering will. Designing a proper crossover for your speakers, and listening to them at quality levels is the best way to keep from damaging them. Power ratings on speakers are a joke and are used more a marketing tool than anything.
Nacimroc
« Reply #2 on: June 30, 2011, 09:16:43 am »
Thanks for that! Will have a look over it and see what I can muster!
matsadona
« Reply #3 on: July 05, 2011, 03:46:16 am »
Hmm... got to ask what you are doing. Is this for an arcade cabinet, or what? Is it a mono application? Since you have the amplifier bridged I guess it is...
I you have 3 8 ohm speakers in parallel, the total impedance will be 2.667 ohms. Are you sure the amplifier can handle that? Not all amps are stable down to 2 ohm.
If you have an piezo tweeter you don't need a crossover (a resistor in series can make it "softer" though...).
However I really recommend that you get/build a crossover for the sub...
Except that I second to everything that mountain already posted.
Blanka
« Reply #4 on: July 05, 2011, 06:28:04 am »
Making a cross-over filter might be an option, but next time get a complete car-speaker set. Then you have 2 or 3 way speakers, with a matching filter at a steal price. Can't hobby against that.
Nacimroc
« Reply #5 on: July 05, 2011, 12:07:05 pm »
Thanks for reply. Your right, but at the time I thought it would be easier than this  ;D.  I tracked down the spec sheet for my tweeter and it shows I need a 8.2 uF cap, so I ordered one and going to mess about and see how I get on. The sound out of the 2 6inch and 10 inch is amazing! It does need tweeters, but for a basic set up its great!
