Author Topic: Faux vector monitor from color crt  (Read 2493 times)
newmanfamilyvlogs
    • Newman Family Vlogs
« on: June 24, 2011, 06:54:28 am »
I've had this idea for a while, but never had the time to play around with it, and was always shocked i never saw anyone else do it.
The basic concept is to disconnect the X/Y yokes and instead of driving them with the circuitry on the chassis, drive them with an amplified stereo audio signal from a PC.
not too terribly different from what's being done here:
If you then feed the display a full-screen solid color in sync with the audio, you essentially get a color vector display. I used to take old TVs and hook them up to the amplifiers in cheap PC speakers to turn them into a visualization for music.
Basically the only work to be done would be a driver that produces the corresponding audio signal for the vector output in mame, and direct it to a secondary audio output.
boardjunkie
  • Last login:March 05, 2019, 06:05:58 pm
Re: Faux vector monitor from color crt
« Reply #1 on: June 24, 2011, 12:37:23 pm »
This is not as simple as it may appear. You need to take into account the geometry correction (pincushion) used in the real x-y monitors. So...while it would technically "work" (its been done before), it won't look the greatest unless you cover all the bases to make it operate correctly.
newmanfamilyvlogs
« Reply #2 on: June 24, 2011, 01:13:23 pm »
Seems like that would be adjustable in the software end.
The only 'external' control would be the 'volume' on the audio amplifer, using the R/L pot to adjust the ratio of width to height.
After a bit more thinking another interesting application would be to take the X/Y from real vector hardware, drive the magnets with it, and perhaps use a small arduindo type device to generate the rgb pin values based off the Z input.
As for where it's been done before, I'd love to see that. This application has never gotten past theoretical in my mind, so to see someone end up with a working (in any sense) model would be pretty cool.
« Reply #3 on: June 24, 2011, 02:30:54 pm »
No kidding...  :applaud:
newmanfamilyvlogs
« Reply #4 on: June 24, 2011, 03:02:31 pm »
Been discussing it with Chad over in the chatroom recently. A friend of his who is more versed in CRT theory pointed out there is an impedance mismatch between traditional vector yokes and raster yokes.
I noticed this over on jrok's site:
http://www.jrok.com/xfer/xystuff/
He commented on it here:
http://www.gamesforum.ca/showthread.php?t=303496
And here's some further reading I haven't dug through yet:
http://hackaday.com/2008/02/25/hackit-new-uses-for-old-crt-monitors/
http://www.instructables.com/answers/convert-any-CRT-TV-or-monitor-into-a-vector-XY-m/
boardjunkie
« Reply #5 on: June 25, 2011, 12:20:18 am »
That was just a yoke transplant. The tube was driven with an Amplifone deflection board. Big difference there....
brad808
  • Last login:May 22, 2023, 08:18:15 pm
« Reply #6 on: June 25, 2011, 07:25:00 am »
I could watch that video for hours  ;D
