Author Topic: 2 shifts perhaps  (Read 1744 times)
lastrega
  • Last login:January 03, 2012, 12:18:19 pm
2 shifts perhaps
« on: June 21, 2011, 06:16:18 pm »
I was just wondering, I have a neo geo syle controller setup..... see pic..... I have gotten all my newer fighters to work very well using my shift key...... question is, Can I make a second Shift key IE player 2 start?   And how can I remove a command... Meaning I have some shift functions on the jotstick and I want to remove them.....
( Example) I have on Mortal kombat, the "BLOCK" button as Shift+1 ( or Start1+button 1).      I can't do scorpians or lui kang's fatality. Simply because when I hold block, them press up it opens my funtions:).... I think that sums it up:) thanks for any help on this....... And I need the second shift key so I can make the second player side have all the buttons for the fighters:)   Thanks again    PS I am using the winipac software.... and I am using a Ipac2  thanks thrice:)
lastrega
Re: 2 shifts perhaps
« Reply #1 on: June 23, 2011, 11:33:22 pm »
Ok I solved my Issue, I think:) My ipac can only support one shift and there is no way around it....... even if it did, when the other shift was used it would affect my side as well,, so hiensight can be a Biscuit, aint it the truth?....... If I had an Ipac4 it has 2 shifts and one does not affect the other.(Hence I could have used the player 3 side for player 2).... But since I had a two player cocktail I thought hey save a buck?  Anyway next time I will either use an ipac4, or just use 6 or 8 buttons....... per side..... oh yeah I got my joystick shift commands figured out as well.....
**LESSONS FOR THE DAY***
1 plan for upgrades
2 plan for the unexpected
3 although rgb buttons cost 7 bucks a piece vs 2 for regular, DONT be a cheapa$% like me. front for the other 28 bucks for a six button rig. Neo-geo config looks great but less functional.
Hope that helps future builders:)
Donkbaca
    • Slim built MAME/Xbox cab
« Reply #2 on: June 24, 2011, 12:14:22 am »
If you are using make you don't need a hardware shift key, you can program an input to be 2 simultaneous button presses
