Author Topic: New Product: Leaf Switch Joystick  (Read 1494 times)
pcb
  • Last login:September 25, 2019, 05:27:26 pm
    • MikesArcade.com
« on: June 06, 2011, 06:30:54 pm »
Just a quick note to let you all know we've had new Leaf Switch Joysticks several months now.  They fit either metal or wood panels.  The center section can be removed for flush mount on metal panels.
Here is the link: http://www.mikesarcade.com/cgi-bin/store.pl?sku=JOYLSNEW
Best,
 - Mike -
« Last Edit: June 06, 2011, 06:35:20 pm by pcb »
Gray_Area
  • -Banned-
  • -Banned-
Re: New Product: Leaf Switch Joystick
« Reply #1 on: June 07, 2011, 08:42:40 pm »
Is the piece around the shaft a kind of restrictor or something?
-Banned-
pcb
    • MikesArcade.com
« Reply #2 on: June 07, 2011, 11:48:13 pm »
Yes, the yellow piece restricts the movement a bit. The black part is a dust washer. The stick is made to fit a hole the size of the yellow restrictor through a wood control panel. However, the stick works fine if the restrictor is removed for mounting flush on the bottom of a wood or metal panel.
« Last Edit: June 15, 2011, 06:31:37 pm by pcb »
