Author Topic: ROWE AMI R-83 disco- no sound problem  (Read 3624 times)
eugeneclark5
  • Last login:August 30, 2012, 11:37:34 pm
« on: June 06, 2011, 10:46:35 am »
Have and AMI r83 that has worked well over the last 2 years, but now is not producing any sound.  I replaced the 4 fuses behind the amp, looked for loose connections, but did notice that one of the 4 red light indicators is not lit.  I also had a remote volume switch connected, but don't know if that could have effected the system.
ami-man
  • Last login:July 19, 2020, 01:22:45 pm
Re: ROWE AMI R-83 disco- no sound problem
« Reply #1 on: June 07, 2011, 08:09:01 am »
Hi Eugene,
What country do you live in?
The amp in the R-83 should be the 125 watt 6-07438-02. The volume control plug does have to be in correct way round.
I assume that the red led you are talking about is on the power supply in front of the amplifier compartment.
Regards
Alan Hood
ami-man
UK
eugeneclark5
« Reply #2 on: June 10, 2011, 02:44:46 am »
Hi Alan,
Live in the US.  Haven't had a chance to check on the connections again, other than to verify that the 28vdc light is not on. the other 3 light indicators are on.
Thanks for your help.
lilshawn
« Reply #3 on: June 11, 2011, 01:20:28 am »
no sound problem
no problem!  :cheers: no sound problem!
i would check the f1001 (3amp) on the power supply and if it's good, the associated circuit for the 28vdc (bridge rectifier, resistors, diodes etc.)
Kevin Mullins
    • Me on Myspace
« Reply #4 on: June 21, 2011, 04:54:00 pm »
Just popping in to say "Hi" to a fellow AMI Disco owner.   :cheers:
(mines not all original, but still love it)
