Author Topic: How to have an LCD auto power?  (Read 3389 times)
Witchboard
« on: May 31, 2011, 02:57:19 pm »
I have a Dell monitor in a bartop I'm building.  It has a rocker switch, so I thought that on would be on, however, it would seem that when I apply power to the cabinet, it goes into standby mode.  I have to manually rock the switch from off to on before the monitor will show the display.  I can't tell you the monitor model type as I've de-cased it and the plastics are long gone.  There are no options provided in the OSCAR to make it power on automatically.  Anybody had a similar issue and know of a resolution?
lilshawn
  • Last login:Yesterday at 05:36:09 pm
Re: How to have an LCD auto power?
« Reply #1 on: May 31, 2011, 09:59:27 pm »
put a jumper on the power button?
if you can hold down the power button and apply power (or flick the "vacation" switch to on) and it powers on your good. solder a wire across the switch.
if not, you might need to get creative.
Witchboard
« Reply #2 on: May 31, 2011, 10:25:13 pm »
It's not a push button, it's a rocker switch.  Soldering across it would do the same thing as the rocker switch in the on position.  I'll try and see if I can get some pics to be more clear.  Thanks for the response.
gryhnd
Completed: No Name Upright
