Author Topic: Can you completely hide the mouse cursor?  (Read 5289 times)
CapriRS302
  • Last login:June 02, 2011, 01:26:47 pm
« on: May 17, 2011, 02:34:41 pm »
I have followed most of the guidelines on the wiki and a few other sources to make my machine have an invisible cursor, but regardless I always seem to see the default cursor flash on the screen for a split second right as windows starts up.
Is there any way to modify that cursor file so that it isn't seen at all?
tel0004
  • Last login:May 28, 2011, 12:24:26 am
Re: Can you completely hide the mouse cursor?
« Reply #1 on: May 17, 2011, 03:20:06 pm »
I wonder if it would be easier to instead to change the cursor to a 1x1 dot (a similar color as the background, which would be unnoticeable.  I question if that would work though, because if the cursor is popping up before windows is fully loaded, then any windows settings have not been loaded yet.
CapriRS302
« Reply #2 on: May 17, 2011, 03:55:19 pm »
Actually I have my cursor set to be 1 dark grey pixel, so that you can barely see it when it moves, but for a split second windows loads its default cursor before it switches.
Also, before I started monkeying around with the registry to hide the cursor, the cursor would disappear when Maximus Arcade loaded up, now when MA loads up I see the cursor on the screen until I try to move it, then it vanishes.  Any ideas?
Blanka
« Reply #3 on: May 18, 2011, 03:21:21 am »
Set up a 2-screen desktop. Let it boot into the invisible one. Or edit the original mouse-cursor image.
Corbo
  • Last login:June 24, 2019, 07:49:12 am
  • I've not seen such bravery
    • Minicade - Mini Gauntlet MAME project
« Reply #4 on: May 18, 2011, 08:04:18 am »
Try this:
http://minicade.blogspot.com/2011/05/hiding-xp.html
Great little tool for hiding the mouse.  It also launches your front end of choice instead of Explorer amongst other things.
« Last Edit: May 18, 2011, 08:06:12 am by Corbo »
_____________________
Wizard needs food, badly!
My mini arcade project:  http://minicade.blogspot.com/
muggsy
  • Last login:October 15, 2023, 01:09:12 am
« Reply #5 on: May 18, 2011, 05:01:23 pm »
I can't recall which package I picked it up from.. but I think it might have been in MameWAH. It was transparent.cur and I used that to replace 3 mouse cursor options... and that hid it for me pretty good
bkenobi
« Reply #6 on: May 19, 2011, 11:20:30 am »
InstantSheller is AWESOME!  It will not work on Vista or Win7 AFAIK, but it does work great on WinXP.
Corbo
« Reply #7 on: May 20, 2011, 05:29:40 am »
Instant sheller is the one on my link, totally agree with you.  I can boot the arcade and shut it down again without a whiff of XP, mouse cursors or anything to take away from the arcade experience.  Brilliant program.
Bender
« Reply #8 on: May 20, 2011, 11:49:29 am »
even with instant sheller the cursor pops up for a slit second on boot up
toward the end of this thread is the only way I've found to completely remove the cursor
CapriRS302
« Reply #9 on: May 20, 2011, 02:50:08 pm »
Guywiththegun
  • Last login:February 17, 2020, 12:00:21 pm
« Reply #10 on: May 20, 2011, 10:54:57 pm »
I used that Instant Sheller program for a while and never had a mouse cursor pop up. Its been a while but I believe it lets you turn the cursor into a single black pixel.
Gray_Area
  • -Banned-
  • -Banned-
« Reply #11 on: May 21, 2011, 02:09:13 am »
I've been using Instant Sheller on one machine, and yes the stock cursor pops up very quickly. Recently, I tried Quick Sheller. It seems better at this, and has more options.
I'm going to back-track on this. Playing around with it more has revealed some issues.
« Last Edit: May 21, 2011, 03:15:19 am by Gray_Area »
-Banned-
bkenobi
« Reply #12 on: May 21, 2011, 05:34:53 pm »
The cursor will show up if you use a standard type cursor and a different colored background.  However, if you want the cursor to be invisible, there is a special cursor you can choose that's a single black pixel.  If you use that and use a dark background, you'll never see it.  If you use that cursor, you won't even notice unless you move the mouse and look REALLY close.
ark_ader
  • I glow in the dark.
« Reply #13 on: May 21, 2011, 06:14:43 pm »
Unplug the mouse.
