Author Topic: Solved:Need wiring help with TB3  (Read 1374 times)
UncleMame
  • Last login:June 10, 2011, 08:47:29 pm
« on: May 17, 2011, 12:28:09 pm »
Does anyone have a link or document to install the TB3 Groovy Gamegear Trackball (wiring/installation) ?
« Last Edit: May 22, 2011, 09:34:04 am by UncleMame »
BobA
  • What Me Worry?
Re: Need wiring help with TB3
« Reply #1 on: May 17, 2011, 12:36:13 pm »
Did you get the opti wiz with it for an interface?
RandyT
  • Last login:June 24, 2026, 02:15:54 pm
    • GroovyGameGear.com
« Reply #2 on: May 17, 2011, 01:07:08 pm »
The Groovy-TB 3" Trackball has three wire pairs, each with .100" spaced connectors.  They are as follows.
Red and Black - +5vDC and GROUND respectively.
Blue and Purple - Y-Axis
Yellow and Green - X Axis
The orientation of the axis connection will vary, based on the encoder wheels ordered.  If either axis is reversed, just unplug that wire pair from the Opti-Wiz, turn it 180 degrees, and re-connect.
