Author Topic: Clamping braces into an assembled Cab  (Read 2157 times)
TheGameFan
  • Last login:September 14, 2011, 12:21:42 am
« on: May 09, 2011, 02:04:49 am »
I am building my first cab from scratch and I got a little over anxious putting it together. I glued everything together, but used very little bracing between the pieces. I made a 2x3 box mounted to 3/4" plywood for the base and have a 2x2 brace running at the seam of the top to the back, but I really don't have anything holding the sides to the top to the or back (aside from the glue between the pieces).
Besides the braces I mentioned previously, there is also a 2x2 running from side to side below the control panel and another above where the coin box would be. The sides are 5/8 MDF and the back, bottom, and top are 3/4 plywood. Is this enough support? It feels pretty strong as-is, but I noticed most cabs have 1x2's along all of the seams.
Since the back is already on, I can't figure out any way to clamp 1x2 or 2x2 strips in the seams to give support (clamps are only a few inches deep). I could use metal angle brackets, but I'm not sure how effective those would be and they would likely accentuate my "noobness" to anyone looking at my cab.
In the works: Full sized Capcom fighter cab, QBert Mini Bartop, Bartop JAMMA / MVS1, Centipede Cocktail restoration
BobA
  • What Me Worry?
Re: Clamping braces into an assembled Cab
« Reply #1 on: May 09, 2011, 02:59:07 pm »
You can fasten the strips in place with a brad nailer or short screws from the inside.  These can be left in place and when the glue dries everything will have extra support.
  • Last login:June 22, 2025, 04:57:38 pm
« Reply #2 on: May 10, 2011, 11:14:15 am »
That's how the original cabs were made anyway.   :)
DNA Dan
  • Guys.. we're not talking gold bars here
  • Last login:September 02, 2017, 11:39:00 am
« Reply #3 on: May 10, 2011, 11:46:32 am »
Get a Kreg mini pocket jig and create as many interior braces as you like.
