Author Topic: Replacing microswitches on Mag-Stik plus  (Read 1265 times)
ramsanus2000
  • Last login:August 21, 2011, 03:59:35 pm
« on: May 04, 2011, 02:43:56 pm »
I hate the switches on my Mag Stik plus sticks.  I was thinking I would replace the stock switches with versa-micros.  As I look closer I notice that the switch on these sticks are unique with shorter actuators.  Anyone know if the versas will fit?  Is it as simple as cutting the actuator with snips or a dremel to the appropriate size?
RandyT
  • Last login:April 26, 2026, 04:29:47 pm
    • GroovyGameGear.com
Re: Replacing microswitches on Mag-Stik plus
« Reply #1 on: May 04, 2011, 02:58:46 pm »
Modifying microswitches is usually as simple as this.  If the metal leaves are too long, you need only to cut them to size.  If you want the VersaMicros with levers, I can make a special version for you. Just make sure to note it in the comments box when you check out.
ramsanus2000
« Reply #2 on: May 04, 2011, 03:48:40 pm »
Custom order placed.  Thanks Randy
