Author Topic: Soft-15khz problem  (Read 2335 times)
Jackalus
  • Last login:September 26, 2016, 08:45:29 am
Soft-15khz problem
« on: May 03, 2011, 05:40:12 pm »
Hello I upgraded my MAME machine from ATI X1550 PCI-E (worked fine!) to AMD HD 5570.
Problem is that now when I set 15khz and reboot the machine (with 11.4 it shows empty adapter info in the soft-15khz for example for 2nd gfx card spot) the screen is split 2 times in the tube(15khz tube) and Catalyst Control Center complains about not finding the gfx card. (Tried with 10.4 too!) When I went to the monitor settings it showed screen has 100hz ?!
Should I use even older drivers (10.2 i used with X1550 I believe). Anyone got experience with Soft15khz and HD 5xxx/6xxx cards?
Thanks a lot. :notworthy:
Edit:
Tried also the DVI port. Forgot to also mention that gfx card names show fine on 10.4 but soft-15khz still fails with double screen.
« Last Edit: May 03, 2011, 07:10:04 pm by Jackalus »
Jackalus
Re: Soft-15khz problem
« Reply #1 on: May 04, 2011, 02:15:51 pm »
Tried with as old as 10.2 (oldest one that supports 5570) and no luck, still dual screen It's like the GFX driver breaks from soft-15khz patches :hissy:
