Author Topic: Anyone programmed an iPac on Windows 98?  (Read 3077 times)
SpAwN
  • Last login:August 09, 2006, 01:41:48 pm
  • Mame Cab done, working on restoring a Wurlitzer
« on: August 28, 2003, 02:08:15 pm »
I tried programming my iPac/4 using the WinIpac software, but it crashes.
I select SW8 for player 4 and whenever I try to type in a key the program crashes, anyone else had this problem? I'd like to program it to be the escape key.
« Last Edit: September 02, 2003, 04:53:58 pm by SpAwN »
Re:WinIpac crash
« Reply #1 on: August 29, 2003, 05:52:58 am »
Might be worth posting this on the Ultimarc board at www.mameworld.net if no-one here can help...
SpAwN
Re:Anyone programmed an iPac on Windows 98?
« Reply #2 on: September 02, 2003, 04:56:40 pm »
Ok I changed the topic of my original post, I'm at a loss, I was hoping someone can help me.
I did a fresh "typical" install of windows 98se, I installed WinIpac and run it. I select a key to map, it crashes for any key I hit. I don't know what could be a cleaner setup, and its crashing. Has anybody done this successfully, I just can't imagine what else I need to do.
BTW, I do have the ALT jumper set correctly, but its crashing on the setup.
I can load .ipc files just fine, if someone could tell me the format, I'd edit the #'s by hand :)
Thanks.
« Reply #3 on: September 02, 2003, 05:07:30 pm »
I seem to remember there is an option where you pick if you have the 2 or 4 player IPAC version - is that setup correctly?
Did you ask the question at the Ultimarc board?  I'm sure Andy if no-one else would see the post and try to help...
If necessary you could search in the IPC file for the keycode which is already programmed for P4 SW8, and replace it with the escape keycode (27).
I have only used WinIPAC in 2k & XP btw :(
Onkel_Tom
  • Last login:May 12, 2004, 06:43:23 am
  • I'm a loser baby, so why don't you help me
« Reply #4 on: September 03, 2003, 05:10:12 am »
I had the same problems (hang). ??? I used the DOS programming utility (in DOS-Box); worked fine. :)
Thomas
SpAwN
« Reply #5 on: September 03, 2003, 09:13:57 am »
Thanks for the tip, I thought the dos utility only worked for 2 players, but now I see that is has a /2 switch. That should fix me up. Thanks.
« Last Edit: September 03, 2003, 11:19:04 am by SpAwN »
Katana Man
  • Last login:September 22, 2024, 12:10:44 pm
« Reply #6 on: September 03, 2003, 12:05:28 pm »
I too have the same issue. Winipac will crash when trying to program it.
I've learned to do it manually by pulling up Notepad and then hit Ctrl-Alt-P.
SpAwN
« Reply #7 on: September 03, 2003, 12:10:08 pm »
what does ctrl-alt-p do?
Katana Man
« Reply #8 on: September 03, 2003, 12:12:26 pm »
It's a built in text based programming method. Try it, and simply follow the onscreen instructions. It's pretty easy.
Bill_S
  • Last login:June 22, 2018, 08:23:57 am
  • aka buzzdalf
« Reply #9 on: September 03, 2003, 12:22:22 pm »
I do it the same way Katana does using Notepad
abrannan
  • Last login:July 25, 2012, 11:32:14 am
  • Building a cabinet in perpetuity since 2002
« Reply #10 on: September 03, 2003, 01:34:48 pm »
Funny, I've never had a problem programming my IPac 2 using the windows utility on Win98.
If no one feeds the trolls, we're just going to keep eating your goats.
« Reply #11 on: September 03, 2003, 01:41:50 pm »
No one yet has mentioned yet PS/2 or USB...could make a difference ?
SpAwN
« Reply #12 on: September 04, 2003, 02:56:11 pm »
I'm using ps/2
I was finally able to get it programmed last night using the ipacutil.exe (dos program)
It was a pain because the defaults for the dos program are different then mame defaults, so I had to pretty much reprogram every button.
I couldn't get the ctrl-alt-p method to work either.
it was frustrating but the results are nice.
Katana Man
« Reply #13 on: September 04, 2003, 03:08:28 pm »
FYI:  I was using USB on 98.  The error we got while using WinIpac was "run-time error 91"
« Last Edit: September 04, 2003, 03:10:01 pm by Katana Man »
SpAwN
« Reply #14 on: September 05, 2003, 10:38:50 am »
I got the same runtime error 91, object reference or with variable not set.
I even did fresh install of windows 98 and only installed WiniPac and still had the problem.
