Author Topic: Emulator list buggy - would appreciate any help  (Read 2828 times)
garykagan
  • No-Edit-Allowed
  • Last login:April 30, 2011, 10:56:49 am
« on: April 29, 2011, 11:05:28 pm »
Hello,
when i look at the other emulators list in the optins for Other Emulators I see many blanks now between some of the items.  I see Daphne (for example), then many blank spaces, then Coleco, then blanks, etc.  It's like they are gone. I checked the emulator config and they are all there.  (attached).  I tried to roll back to 1.05 and it got worse.  only one showed in the list.  I tried going to 1.742 and it went back to the orig problem.  When I try to use the mala tree and goto Intellivision which was setup, it now does not show any emulator selected.  like it is gone.  I thought a fresh install would fix, but now i don't know what to do.  I don't want to delete all my configs and start again.
loadman
  • Moderator
  • Last login:Today at 01:54:36 am
  • MaLa FE developer
    • MaLa
Re: Emulator list buggy - would appreciate any help
« Reply #1 on: April 30, 2011, 01:20:28 am »
Hello,
Hi, I don't see you have any other choice but to set up MaLa again if the files are corrupted.
I don't have other reports of such issues.
In other posts you mention other weird symptoms as well.
What I will recommend.
- Never go back MaLa versions with the same config. Newer things have been added that could scamble config (the Other EMU stuff in particular). Better off keeping a copy of your old mala setup. There is also a section to backup MaLa files within MaLa.
- As a general practice backup all you emu stuff to somewhere. External Hard Drives are pretty cheap these days.
« Last Edit: April 30, 2011, 01:24:07 am by loadman »
garykagan
  • No-Edit-Allowed
« Reply #2 on: April 30, 2011, 10:56:49 am »
Loadman,
Thanks for the reply.  I will go back to a working backup i have on another drive 1.05 and start from there.  That version was definately working before.
thanks man,
Gary
