Author Topic: Using a Arcade PCB for a bartop  (Read 2188 times)
jmike
  • Last login:April 22, 2026, 08:42:39 pm
« on: April 26, 2011, 08:17:42 am »
Hi there,
      I recently purchased a Run and Gun 2 motherboard from another member and I'd love to build a bartop around it. My problem is I'm not really sure how to make it work. I've been searching/reading as much as I can and the only thing I was able to figure out was that I need a video converter if I want to use a LCD montor (found on Paradise arcade shop).
Can someone tell me what kind of power supply I need to make this run? I know I should have thought about this before the purchase but I used to love Run and Gun 2 growing up, and well since it's not working in Mame yet, this is the next best thing. Also need to figure how to hook up controls to it as well. :dizzy:
I saw the manual of Run and Gun 2 on Ebay but since I'm not using a arcade monitor, I'm not sure it would help much.
Any help would be greatly appreciated.
Re: Using a Arcade PCB for a bartop
« Reply #1 on: April 26, 2011, 09:38:10 am »
Is that a JAMMA board?  You could buy a JAMMA harness on eBay or elsewhere and use that to connect your controls, video converter, and power supply.
You can buy a switching power supply (like one in a regular arcade cab) or you could probably use just a regular PC power supply.
jmike
« Reply #2 on: April 26, 2011, 10:50:44 am »
Thanks HarumaN,
       I believe it is a Jamma board. Glad to know I could use a regular PC power supply, I think I can find everything at Paradise site. But i might be better to get the manual, I think I saw it on Ebay or something.
« Reply #3 on: April 26, 2011, 10:53:26 am »
You don't need the manual.  Most likely you can find the manual in PDF format somewhere on the net.
jmike
« Reply #4 on: April 27, 2011, 11:36:35 am »
 :hissy:  Too late. Bought it on Ebay yesterday. Luckily it was only $9 shipped. Also ordered the rest of the hardware from Paradise Arcade.
