Author Topic: Dremel instead of router?  (Read 3211 times)
Marcade
  • Last login:March 12, 2012, 04:58:53 pm
« on: April 22, 2011, 05:38:43 am »
Anyone used a dremel in place of a router?
I've always wanted a dremel as they seem like a useful multi-tool and I don't have a router and am finding it difficult to get access to one.
I've tempted to get a dremel as I wont be putting all my money in one basket so to speak, but would it be any good for the t-molding slots?
It's only a bartop so hopefully wouldn't need too much messing with a router...
On the other side of the screen, it all looks so easy...
BobA
  • What Me Worry?
Re: Dremel instead of router?
« Reply #1 on: April 22, 2011, 08:21:55 am »
The dremel does not have enough power to cut t molding slots.  The router attachment for it does not work well and leaves the tool unstable and dangerous.  I have one and would never try to use it to cut t molding slots.
saint
  • turned to the Dark Side
  • Supreme Chancellor
  • Last login:Yesterday at 02:45:35 pm
« Reply #2 on: April 22, 2011, 08:29:58 am »
Yes I have, and NO NO NO NO NO NO NO!
Results with Dremel: Poor, and difficult. Results with router: Excellent, and amazingly quick. Invest in a router if you're going to do any kind of wood working. You won't be sorry.
--- John St.Clair
     Project Arcade 2!
     saint@arcadecontrols.com
TopJimmyCooks
  • Last login:July 12, 2026, 05:42:15 pm
« Reply #3 on: April 22, 2011, 11:21:58 am »
Get a cheesy laminate trimmer like
http://www.harborfreight.com/1-4-quarter-inch-trim-router-44914.html
Add a bigger base on it - unfortunately I don't have a pic of this because I have some full size routers.  Let me know if you don't understand- the clear plastic base can be drilled for mounting holes and have a second, larger base (like 1/4" plywood) added underneath.  this will give you more stability to keep a t mold bit aligned.
It's underpowered for a t mold bit, so on your first passes, don't push the bit's ball bearing all the way to the edge of the wood.  let it cut a little wood out of the slot at a time.  Do not try this with just the small base on the trimmer, not enough contact with the face of the wood to be stable.
Be careful and safe.
Marcade
« Reply #4 on: April 22, 2011, 04:20:12 pm »
Ok thanks everyone, scratch that dremel idea!
