Author Topic: Changing colors on an image  (Read 1406 times)
gamepimp
  • Last login:April 06, 2025, 08:48:37 pm
« on: March 30, 2011, 09:30:02 am »
Hi all. I'm trying to change the coloring on some block letters I found on the 'net. The letters are silver and have kind of a shiny effect. I'd like to have these letters in red, blue, green, and yellow for some backgrounds I'm working on for my arcade machine. Does anyone know how i can change the colors on these letters and still retain the effect properties that each one has? I found an example of a red letter to illustrate what I'm trying to do. Someone has obviously done some recoloring of these type of letters at some point. However, I can't find red, blue, green, or yellow versions of the "A", "E", "M", and "G" letters that I need for my background. I have downloaded the Paint.net program which I thought would help me change the colors on these things. But so far I have had no luck figuring out a simple way to do this using that program. Any help would be greatly appreciated.
« Last Edit: March 30, 2011, 09:32:12 am by gamepimp »
scream1973
  • Last login:July 25, 2014, 10:28:46 am
Re: Changing colors on an image
« Reply #1 on: March 30, 2011, 09:48:42 am »
I don't know how to do it in Paint.net but in Photoshop you can do a color adjustment for the highlights/shadows/midtones to bring the colors where you would like.
Try seeing if Paint.net has the capability for a color adjustment layer.
gamepimp
« Reply #2 on: March 30, 2011, 10:17:14 am »
I'll look for that. Thx for the info.
tsaylor
  • Last login:April 20, 2019, 05:16:20 pm
« Reply #3 on: March 30, 2011, 10:54:10 pm »
Probably the easiest thing is to use Hue / Saturation (ctrl+shift+U) to tweak all the colors at once.
